Offset?
Old Mar 9, 2004 | 09:07 PM
G35_Girl's Avatar
Offset?
I know what each number of 245/40/18 means but what does offset mean to a rim? Is that the length from the axle to the rim or something like that? Thanks
Old Mar 9, 2004 | 09:45 PM
Meatshackle's Avatar
Deep Sea Moderator
Re: Offset?
This might help......
http://www.tirerack.com/wheels/tech/offset.htm
The higher the number, the more tucked in the wheel will be.
Example: You find a wheel with a +28mm offset and it won't fit over the Brembos you need to go lower. You see a wheel you like with an offset of +23mm but you think it sticks our too much, you need to go higher.
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest Monitors Thread
seagrasser
May 3, 2022 09:43 AM
Picture Share
Feb 4, 2018 12:41 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
TurTLe*
Sep 29, 2015 01:43 PM
