what do you think 18s or 20s?
Old Jan 13, 2008 | 06:00 PM
2004neonsrt4's Avatar
will be summer wheels/tires only what do you guys think/know from personal experience's in the difference in 18s to 20s. looking to get these for my bone stock 04 g35x in either 18x8 +40 with 245/45 shown here
http://www.tirerack.com/tires/tires....e1=yes&place=0
or the same tire on 20X8.5+42 wheel in the same style with 245.35.20s
http://www.tirerack.com/wheels/Wheel...4&autoModClar=
also undecided on which drop springs to purchase. i don't want to go hunting for oem 350z or coupe springs that are used. I'm looking right now at the eibach pro kit for the sedan. which is 1.1inch drop front and rear. this should keep the camber and non sport shocks in check.
Old Jan 13, 2008 | 06:02 PM
g35freak86's Avatar
19's. 18's are too small and are good for track cars and reaching ultimate performance. 20's are took big and take away from the performance.
Old Jan 13, 2008 | 06:08 PM
black_sedan's Avatar
20s are pimp... just ask ttrank.
Old Jan 13, 2008 | 06:10 PM
O HELLA OEM's Avatar
20's FTMFW!
Old Jan 13, 2008 | 06:18 PM
CandlestickPark's Avatar
ill Sedan
If you are considering 20s then go with those. Anything smaller may end up looking too small to you. Personally I'd go with some lightweight 19s, good balance between performance and looks.
Old Jan 13, 2008 | 06:37 PM
i want 19s but cant find any i like in the norm of price ranges more importantly all the tires i like for the 19s are 200+
Old Jan 13, 2008 | 06:40 PM
ill Sedan
Have you considered Coupe 19s?
Old Jan 13, 2008 | 06:47 PM
GixxerSteve's Avatar
Then perhaps you should look at a different tire. I have the Kumho Ecsta SPTs on mine, cost me around $175 each. 245/35-19 front, 255/35-19 rear on coupe 19's.
Old Jan 13, 2008 | 07:06 PM
i have, i like the coupe 19s. but havnt seen (so for im new) to many pictures of them. what are there usual price range?
Old Jan 13, 2008 | 07:17 PM
ill Sedan
I've seen then go for around $600 or so up to $1200+ depending on the condition the wheels and how much tread is left in the tires.
Check out this thread if you haven't already: https://g35driver.com/forums/19-inch-304/
Old Jan 13, 2008 | 07:45 PM
FlyingLumpia's Avatar
He is awd, so the coupe wheels are staggered. With awd you should not run staggered. Even though I think you could just run 245/40/19 or 245/35/19 and get away with it. But I would not try and run staggered.
As for 20's. They are not that big but you do lose alittle performance.
Old Jan 13, 2008 | 07:51 PM
ill Sedan
^Good point, I didn't notice he had AWD.
Old Jan 13, 2008 | 08:15 PM
jserman's Avatar
GO 20's or go home....just keep an eye out you should be able to find some rims fairly cheap....
tires for 19's and 20's are about the same even thought I have heard 19's are more $$$ and harder to find....
Old Jan 13, 2008 | 08:54 PM
yeah i can get a good named/style 20inch tire for 140 a piece or a no name decent tire for a 19 for almost 200. i like 20s but don't want to spend a ton of cash for suspension work to make it look right. will a eibach pro kit with -1.1 drop f/r be enough? i would think 350htech would be the best looking but would need new rear shocks and camber kits f/r
Old Jan 13, 2008 | 09:49 PM
id suggest using some springs that are specifically for the sedan. there was another member that ran the 350z s-techs on his sedan and the drop was unproportional front to rear.
i have both a set of coupe 19s and 20s and the tires for the 19s are $30-$40 more per tire than the 20s.
