what the different between Y & Z series tires
Old Jan 16, 2008 | 05:15 PM
Thuktha22's Avatar
I am looking for tires. and i was wondering if anyone know what the differnt in a Y and Z series tires? I call a tire shop and they said they got some KHUMOS Y series tires in stock. but i've been hearing Z series are better. can some one please tell me what the differnts between them or are they the same thing?
Old Jan 16, 2008 | 05:30 PM
06g35meister's Avatar
speed rating, one is like 145 and the other is like 156, but a y will last much longer cause its harder (most of the time)
Old Jan 16, 2008 | 05:33 PM
patman530's Avatar
Y is a subcategory of the Z speed rating. Y is rated for up to 186mph. Z indicates speed rating of 149mph+.
You can't go wrong with the Y speed rating.
Old Jan 17, 2008 | 10:32 AM
Q45tech's Avatar
Remember speed rating are for brand new tires tested on a lab machine at 70F with ZERO CAMBER ON THE TIRE.
Raising tire temperature or setting any negative camber greater than -0.5 degrees will make these test less useful.
As will having more than a few thousand miles on tires!
Tires are tested just after a 250 miles break in period and won't explode until a few miles per hour above rating.
They are tested with maximum load weight on tire so this buys a little since most don't load them quite that high.
Old Jan 17, 2008 | 11:58 AM
Klubbheads's Avatar
^nice, so im safe with 160mph with my toyos.
Old Jan 17, 2008 | 12:01 PM
IPSECG35's Avatar
Do you work in the industry? How do you know this?
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
socaldavid
Sep 5, 2015 04:35 AM
TheBay
Sep 3, 2015 03:27 PM
