Wheel Stud question
Old Jan 26, 2008 | 09:16 PM
FlyingLumpia's Avatar
Wheel Stud question
Just wondering if the front stock studs are the same as the rears. I strip one of mine in the rears, but I got the front ones since I have spacers on the front.
Thanks for the help.
Old Jan 27, 2008 | 02:57 AM
Jason@Riverside's Avatar
Well, you generally do not want to re-use wheel studs since the knurl gets compressed once pulled into the hub, it does not fit securely the 2nd time around and you can wrisk the hub bolt spinning freely in the hub so you wont beable to tighten a lug nut or take a lug nut off...
The stock wheel studs are longer in front and shorter in the rear, but have the same 14.3mm knurl diameter.
Old Jan 27, 2008 | 03:41 AM
Ok thanks. Dang dont thing the parts department is open tomorrow. I guess I will have to wait until Monday. Or maybe I will just order up some 10mm spacers.
Old Jan 27, 2008 | 01:41 PM
The 10mm spacers will have new longer hub bolts
Old Jan 27, 2008 | 01:51 PM
Yeah, I know that. I am just debating what I want to do now. I was trying to save a few dollars but I think I might want to put the wheel out more.
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Detailed Image
Jul 24, 2015 12:31 PM
si_driver
Jul 14, 2015 12:29 PM
