rays 19" question
Originally Posted by OCG35
I'm getting CE28Ns in 19 X 8.5 with T1Rs 245/40/19... I guess I'm in the horrible category
Originally Posted by superb16
Yeah, 245/35 would look MUCH better.
I agree that the shorter profile looks good… there are other considerations (for me anyway) – a little extra rubber to protect the over-priced wheels and the 40 series fills out the wheel well a bit (26.7 diameter vs OEM 26.3 diameter) 35 series is a bit smaller, 25.8 diameter… the speed ratio is small – speedo is 1.5% too slow with the 40s, 2.1% too fast with 35s
This isn’t to say that 35s aren’t a good option – they look great… But 40s have some things to consider that are a plus for some people (these considerations are what drove my decision).
i am in need of new tires and was thinking of going with something a lil wider, or a spacer maybe? i would really like the rims to sit flush with the quarter panel...
i believe it sits on 245/40/19's right now...
Q50 Red Sport 400 RWD
Two: 225/35/19s and two: 245/35/19s Dunlop Direzzas $660
Two: 225/40/19s and two: 245/40/19s Bridgestone Potenz RE50 $1020
Plus, with the Direzzas(according to superb16) you don't need to roll the rear fender lip for clearance, even with 1" drop. I have read that the direzzas are quieter than the Bridgestone's as well. Plus, the direzza is not available in 40 series...and 35 series looks hawt.
Hopefully speedo error is negligible and roads are good in general in my area....but generally speaking...a pothole that focks 35 series will also fock 40 series.......12mm is not going to save you..lol
Falken Azenis st115 is a good choice too.
235/35 front
245/35 rear $720 total.
Question, would it be better to run 245/35 on all 4 corners for equal side wall height
on a 245 wide tire 40 series is actually closer to OEM specs than 35 series...
with a stock 19" wheel and 245/35-diameter is 654.1 mm(14.2mm shorter)
with a stock 19" wheel and 245/40-diamer is 678.6mm (10.3mm taller)
Originally Posted by Texan1
actually no, with a stock 17" wheel and tire--the diameter is 550.05 mm
with a stock 19" wheel and 245/35-diameter is 568.6 mm
with a stock 19" wheel and 245/40-diamer is 580.6mm
245/40/19 = 26.7"/678.6mm - a difference of .4"/10.3mm
245/35/19 = 25.8"/654.1mm - a difference of .5"/14.2mm
so in this case 245/40/19 are closer to OEM diameter than 245/35/19
Edit: I just realized your calculations are the same as mine... how do you figure 40 series in not closer to OEM diameter than 35??? You listed the difference and indicated implied that it is not??? It doesn’t matter if it’s taller of shorter when the statement was referencing “closer”
