Will this offset fit my sedan?
Old Feb 14, 2008 | 01:53 AM
Granto86's Avatar
I am gonna buy some coupe 19s from a member here and I just wanna make sure they fit, I have a 04 sedan with sport suspension no brembos, and am not lowered, but I would like to get 350z h-techs in the future, so with those wheels, would I need to get my fenders rolled or get any spacers?
The offsets are
Front: 19" x 8" +30mm offset (Tires are 225/40/19)
Rear: 19" x 8.5" +33mm offset (Tires are 245/40/19)
Any advice would be great!
Old Feb 14, 2008 | 01:54 AM
Klubbheads's Avatar
Yes, need to shave/roll the fenders though.
Old Feb 14, 2008 | 01:57 AM
Granto86's Avatar
Really? with my stock suspension now? or when I get lowered? ttrank said it would fit fine with my suspension as is but i needed some more opinions before I drop all the money.. will the +30mm offests be okay?
Old Feb 14, 2008 | 02:12 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
you'll be fine. You might rub slightly in the rear at stock height, but i doubt it. If you do, all you need is a very slight fender roll, very easy to do.
-GP-
Old Feb 14, 2008 | 03:33 AM
03Sg35's Avatar
I have Htechs and coupe rears for drop and same wheels and tires on my 03 no rubbing issues at all go for it, if you want to see pix check out the picture tread
Old Feb 14, 2008 | 10:46 PM
OCG35's Avatar
hmmmm now I'm wondering if mine are gonna be an issue: 19 X 8.5 +35 w/ 245/40/19
slightly lowered on Eibach Pros?... Grant, or anyone?...
Old Feb 15, 2008 | 01:57 AM
FlyingLumpia's Avatar
right now I got a 20x8.5 +40 but I am using a 5mm spacer up front and I am running 350z s-tech no problems and I might be going lower.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
teamghost
Jul 28, 2015 04:52 PM
joedaddy1
Jul 28, 2015 02:58 PM
