Damaged 3 Piece wheels :-( Should I get them fixed or...
Old Feb 14, 2008 | 02:26 AM
Element G35's Avatar
Ok so I have some DPE S-20 wheels (3 piece) my options are get it locally fixed for $110 each (i have 2 that are damaged) and the local shop told me that if they crack then they have to weld it and it will be another $60 so $180 a piece. They give me a 1 year warranty on the weld.
Option 2: Send it to DPE so they can install the new inner lip on my wheels ($250 each).
Old Feb 14, 2008 | 03:00 AM
redlude97's Avatar
By inner lip you mean the piece of the barrel on the inside of the wheel that is not visible correct? If so, I would just get them fixed. If its the outer piece thats polished, I would opt for new pieces
Old Feb 14, 2008 | 12:16 PM
waijai's Avatar
i.love.gold
Get em fixed, shouldn't be an issue. I've had my iForged repaired a few times w/o issues.
Old Feb 14, 2008 | 12:18 PM
Hi-TechG35's Avatar
Fix them. They are well worth it.
Old Feb 15, 2008 | 03:46 AM
Yes the side that is NOT visible, the side that is closest to the brakes. Anyway The thing is that it might crack and if it does i'll have a welded wheel..
any issues with a welded wheel? maybe durability or rough driving?
Old Feb 15, 2008 | 03:53 AM
scarface_613's Avatar
fix them
Old Feb 15, 2008 | 09:11 AM
GreenGoblin's Avatar
The goblin resurrection
nope the weld should be stronger than the actual hoop
bu villain
19 Inch
Nov 15, 2015 09:23 PM
Jussaku
Aug 4, 2015 12:45 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
