axis mod help please!!
Old Feb 19, 2008 | 11:19 PM
edgecrusher230's Avatar
hi i tried searching but I cant find the answer im looking for. Woild anyone be able to tell me if Axis se7en mod wheels 19x8 +35 fronts and 20x10 +38 will clear brembo brakes? A friend of mine had them on a 350z without brembo's and the fit slighty tucked.
Any spacer recommendations?
Old Feb 20, 2008 | 01:10 AM
panda007's Avatar
Offsets sounds a bit too conservative. Try to go mid 20's for a "safe" yet flush look. Not sure if they'll clear brembos, but with spacers, I am sure they will. Any reputable branded spacers with hubs will work fine (Kics, H&R, etc). I had H&R and had to replace my studs for extended ones, which i prefer more over those spacers with embedded studs (a la Kics).
Are you buying your friend's wheels?
Old Feb 20, 2008 | 01:12 AM
rookie's Avatar
Mods don't have much caliper clearance. 20mm all around probably be good.
Old Feb 20, 2008 | 01:22 AM
THE_SCHROED's Avatar
I was wondering if anyone would buy my rims because of the same thing. I got some rims on my z right after I got it but didn't check the offsets. They are 18x8 18x9 +40 all around. Is that a good offset for the sedan?
Old Feb 20, 2008 | 08:22 AM
Thanks! I was going to get 15mm spacers but I'll go with the 20mm now.
Yes I am buying my friends wheels.
Old Feb 24, 2008 | 03:08 PM
rx7/350z's Avatar
Old Feb 24, 2008 | 03:26 PM
redlude97's Avatar
I would go 25mm all around, those offsets are horrible
Old Mar 10, 2008 | 12:02 AM
Cersoft's Avatar
Just for people's info, the front (not sure about the rear) Axis mods DO NOT have recesses for the studs on 20+ mm spacers, looks like I'm gonna have to throw on the spacers and then grind down the stock studs ...
Old Mar 10, 2008 | 03:45 AM
Cersoft's Avatar
(changed subscription option) ...
Old Mar 16, 2008 | 11:05 PM
Here it is!
I needed 25mm spacers in the front and nothing in the rear
Old Mar 17, 2008 | 02:05 PM
Cersoft's Avatar
Yeah, I ended up with 25mm spacers in the front, I'm gonna go with 15mm in the back with a reduction of -ve camber (cos I'm lowered) ... I'll post pics of the fronts tonight ...
Old Mar 17, 2008 | 02:09 PM
Hi-TechG35's Avatar
Offsets are way too conservetive. Offsets for coupes with Brembos shouls be low 20's at least.
Old Mar 17, 2008 | 10:24 PM
Cersoft's Avatar
Ta daaaa ....
Old Mar 17, 2008 | 11:41 PM
Originally Posted by Cersoft
Ta daaaa ....
It looks good bro,
How much did you lower it?
Are these pics with the spacer in the rear?
Old Mar 18, 2008 | 12:47 AM
Cersoft's Avatar
The ground to fender height right now is 26.75 inches all around, not sure how much that is lower than stock.
There are currently no spacers in the back, I'm planning on putting 15mm spacers in the rear and reducing the -ve camber somewhat ...
Charchar66
Dec 19, 2019 01:17 PM
Video Share
Jan 31, 2017 04:00 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
RWDguy4238
Sep 30, 2015 12:13 AM
