How good are these spacers??
Old Feb 21, 2008 | 03:09 PM
purplebeast's Avatar
http://cgi.ebay.com/ebaymotors/PAIR-...em270212409131
I need some and I was thinking of getting them
Old Feb 21, 2008 | 03:16 PM
ShanesG's Avatar
they prob suck, spend the money and get the right ones!
Old Feb 21, 2008 | 03:19 PM
JOKER's Avatar
CLUB MODERATOR
I would not worry about quality when you go with such thin spacer.
You are using just a studs to hold the wheel.
If you go with a bigger spacer that has studs built in then a quality is something to worry about.
But in this case just get longer studs and you shall be ok with those spacers.
All they are is just a washer between the hub and the wheel
And quality does not really matter.
Old Feb 21, 2008 | 03:21 PM
I was also thinking about getting the 12mm spacer, same kind as the one posted. Is that too think u think for this "cheap" type of spacer?
Also Could I just go to discounted auto parts and buy longer studs or do I have to ordered it online?
Thanks
Old Feb 21, 2008 | 03:26 PM
JOKER's Avatar
CLUB MODERATOR
Thanks
You could prolly pick up longer studs in any auto parts store.
As I said. When a spacer small enough that it does not have studs built into it then I would not worry about quality. But when you go higher then you might want to pickup something light and properly made.
Old Feb 21, 2008 | 04:36 PM
redlude97's Avatar
I would not use 5mm spacers without extended studs, one of the local members snapped 2 of them off running 5mm spacers without changing his studs within a week of installing them, 3mm is the most I would use without replacing the studs
Jusseth
Sep 13, 2020 12:25 PM
hdmark
Apr 29, 2019 04:31 PM
laksjd84
Steering & Suspension
14
Aug 8, 2015 11:47 AM
deathsupport
Canada
Aug 2, 2015 10:13 AM
