Falken Tires
Old Mar 3, 2008 | 10:38 PM
Texan1's Avatar
Q50 Red Sport 400 RWD
Originally Posted by Texasscout
I got my ST115's installed and with bal and Road Haz for $822.00 for 245 35 19's
($181 per tire)
did you go to disc. tire? The closest I can get to that is $840 with no $10 disposal fee, skip the $30 per tire certificates of repl. +52 install/life balance and $64 tax.(unless they want to negotiate)
If I take them my coupe 19 wheels for them to mount, the price should not be any diff. right? It will actually be easier, since they don't have to dismount tires from the 17s.
How is the ride on the 245/35/19s. That is the size that I will be going with on my new coupe 19s. I just can't make up my mind on azenis or fk452. What wheels are you running?
I want the 35 aspect ratio b/c this should prevent rubbing on the rear with a 1" drop. They are 86mm tall which is 4 mm shorter than a stock m3 setup(not bad). Speedo should be 1 mph too fast and an overall height of 654.1mm vs 668.3 on my stock 17s. This is w/in 2.13% of stock and it's recommended to be within 3% of the stock height for brake performance etc.
Old Mar 3, 2008 | 11:09 PM
Texasscout's Avatar
Yes is was Discount Tire
What happened was, I got a quote for Goodrich UHP's for that price over the web. It said that they were in stock at the Corpus Christi Dealer. When I went there, they said it was a two month wait on them! But he said "I can get you the Falkens for the same price and he did what your are saying except I do have the hazard on them.
The ride is everything I had hoped for. The only thing wrong is the speedometer is 2.5 mph FAST now. I should have gotten 255 or 265 40 19's instead. The M45 sport rims are a full one inch wider (8.5") than the stock G sport wheels.
Old Mar 3, 2008 | 11:37 PM
Texan1's Avatar
cool, how is the ride on those 35 series tires?
Old Mar 4, 2008 | 01:32 AM
Beebo's Avatar
Originally Posted by TURBOTOM
Anyone go from T1r's to the Falkens?
i did i love the Falkens so much more...
Old Mar 4, 2008 | 02:25 PM
Texasscout's Avatar
I went from 245 45 18"s to 245 35 19's
I did notice a slight increase in ride harshness that was more than made up by the steering reponse and turn in. The rain traction is as good or better than the Goodboot RS-A's (I didn't think it could get better than that) and the noise is less.
Old Mar 5, 2008 | 01:42 AM
Texan1's Avatar
ok, thanks.
Old Mar 5, 2008 | 04:34 AM
in2win's Avatar
Ive had fk452's and falken azenis, azenis handle slightly better buts thats only when they are pushed to the limit or so Im told I will only drive on falkens, great tires...period.
Old Mar 5, 2008 | 11:44 AM
chester's Avatar
is it just me or the inner side of the falken 452 looks thinner than the t1r which would make these falken worn out faster than a t1r on some negative camber?
Old Mar 6, 2008 | 02:33 AM
Texan1's Avatar
so if you had to recommend one over the other in general, which one would it be?
come on your comparo was kind of weak
Old Apr 6, 2008 | 06:05 PM
releasedtruth's Avatar
Not just which to recommend, but what sort of life are we talkin on the rears with stock setup?
Old Apr 6, 2008 | 07:24 PM
in2win's Avatar
Falken fk452's for the win, great tires and Im on over 25k miles on my last set and I drive pretty spirited, but no burnouts falken azenis are somewhat more expensive and the fk452 is just as good for hard driving and excellent tire wear.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
