Tire Plug
Old Mar 4, 2008 | 10:30 AM
rsx004's Avatar
Tire Plug
I know I am probably being paranoid but last night I saw something stuck in my tire and assuming it was a rock (dark outside) I tried to pry it out with my key. After a couple of tries I realized it was a tire plug from when I picked up a nail a couple of months back.
Could this have loosened the plug enough for it to come out or leak air? Don’t want my fiancée driving down the highway and loose a tire...
Any thoughts?
Old Mar 4, 2008 | 10:38 AM
gary c's Avatar
Tire plugs....?
There's not a "Good" tireshop on the planet that would plug a radial tire. Yes,
I've seen it done but I wouldn't allow it on my car. If you have a nail in your
tire it should be patched which takes a little time, pluging is fast, easy and
cheaper for the tireshop....and wrong!
Old Mar 5, 2008 | 09:40 AM
rsx004's Avatar
Thanks. Anyone else?
Old Mar 5, 2008 | 11:56 AM
SilverII's Avatar
should be okay... those things are a bitttch to get out using your car key.
Old Mar 5, 2008 | 12:16 PM
giddyup69's Avatar
patching isn't 100% ideal either. it still leaves the original hole on the outside. moisture can come in causing the steel belts to corrode possibly leaving the tire weak. to be honest our work van has had multiple plugs put into the tires because it's out on a lot of job sites, and i've never seen any of the plugs fail or the tires to lose air.
to the op ... if you've got a lot of tread life left in that tire... just take it back and have them add the patch, otherwise i would just leave it. i'd do whatever to put my mind at ease.
JoeMac
Aug 20, 2015 10:17 AM
Tukeeg35
Engine - Electrical
Aug 19, 2015 02:08 PM
linedr89
Aug 17, 2015 05:11 PM
yassy
Aug 9, 2015 07:31 PM
wuppiedog
Aug 7, 2015 11:16 AM
