how can i get this to fit?
Old Mar 4, 2008 | 11:16 PM
KapVu's Avatar
I know I might get some flames for this, but I don't care. I actually like these wheels and they look good to me. How can I get them to fit though?
Wheels Here
Brand : ADR M-Sport
Bolt pattern : 5 x 114.3
Size : 19 x 8.5(front) & 19 x 9.5(rear)
Offset : 35mm(front & rear)
Lip size : 2.5" (front) & 3"(rear)
Finish : Hyper Black With Machined Polished lip
I know ADR's aren't the best but they do look good on 350z and I've seen them in person on other cars plus one Z. They don't look bad at all.
With the 35mm offsets, can I get some spacers to get them to fit without rubbing? Would I have to roll my fenders? What spacer sizes should I run? 20/25? 15/20?
I really like the flush look. Also my car is NOT drop at all, but MAY (just a maybe) drop in the future with 350z H-techs.
Thanks for the help.
Old Mar 4, 2008 | 11:21 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
20mm spacers front and rear.
-GP-
Old Mar 4, 2008 | 11:25 PM
SlooberTooth's Avatar
WHy are those bad rims? Is ADR a bad company or something?
BlueDevilBAMF's Avatar
Not to thread jack, but if it's a 35mm offset and you get 20mm spacers, is that essentially equivalent to a 15mm offset?
Old Mar 4, 2008 | 11:33 PM
KapVu's Avatar
I believe so. Also I have the Brembos, this should clear them should they not?
Old Mar 5, 2008 | 12:48 AM
redlude97's Avatar
I would go 30mm spacers all around and roll your fenders
Old Mar 5, 2008 | 01:07 AM
KapVu's Avatar
30mm? that's really big. Why would you do that? And would that be safe?
Old Mar 5, 2008 | 01:10 AM
redlude97's Avatar
Because that is the size of spacer that would be need to make those wheels flush and look good IMO. The offsets are horrible to start with, so extreme measures would be needed to get them to look good to me
Old Mar 5, 2008 | 01:56 AM
KapVu's Avatar
how safe is it to run 30mm spacers? or even 20mm spacers?
Old Mar 5, 2008 | 08:43 AM
reverse's Avatar
let me guess...u saw those on ebay for $650 right? take a look at those RUFF wheels, u can get a +20 offset & they almost look the same if not better. but i am not sure about the weight on either of these, if that might be a concerne of yours. just seems like alot to go through to save a buck.
Old Mar 5, 2008 | 05:04 PM
KapVu's Avatar
What RUFF wheels?
Like I said in my orignal post, I like these wheels and I've seen them before. They do look pretty good. I did some searching and looks like a lot of people are running 25mm spacers. How well will that make it fit with brembos? Again, i'm at stock height.
Old Mar 5, 2008 | 05:10 PM
What RUFF wheels?
Ruff Racing wheels... they make a lot of styles and they're inexpensive - probably because they're heavy and not very good quality.
Old Mar 5, 2008 | 05:20 PM
KapVu's Avatar
I meant what Ruff racing wheels look like the ADR's? I checked and didn't see anything similiar.
Old Mar 5, 2008 | 05:36 PM
I guess these sorta do:
http://www.wheelfire.com/scontent/Wh...859&CheckFit=1
Not nearly as nice looking IMO
Old Mar 6, 2008 | 08:20 AM
reverse's Avatar
naw, these Ruff 281's....alot those cats on my350z run those. but the offset is better.
http://www.statuswheels.com/wheels/w...=45&brand_id=2
