PLEASE HELP!! So my inner rear tires are worn the hell out
Mar 12, 2008 | 07:14 PM
I went to get an oil change and firestone told me i need new rear tires.
Thread depth:
left front Outer is 7 Inner is 5
right front Outer is 7 Inner is 5
right rear Outer is 5 Inner is 2
left rear Outer is 5 Inner is 1
The guy said the rear tires need to be replaced because 2 is dangerous and 1 is illegal in the state of hawaii. I just bought these wheels used and i dont wanna be buying new tires every 5k miles. Its way too expensive since my rears are like 10 1/2 inchs wide.
What do i need to do??I understand this is negative camber but Im a noob with this ..Do i need a camber kit?? Rear arms?? Nothing i can do??? Please let me know before i go waste money on new tires to have the inner part wear away again.
Im on Tein S-techs with 19's
Reply 0
Mar 12, 2008 | 07:25 PM
You need to install a rear camber kit. Make sure it is installed correctly. You have to elongate holes when installing the kit. After that, get an alignment and you should be fine.
Reply 0
Mar 12, 2008 | 07:26 PM
what are your current alignment specs. You can have the tires flipped so that the inner tread is now on the outside to prolong the life a little longer. Sounds like a you need a rear camber kit though. The SPC(eibach, ichiba) kits with toe bolts are the most cost effective choices for the rear camber kit.
Reply 0
Mar 12, 2008 | 07:29 PM
Here's a DIY to get a better idea of what youre going to need....
http://turboneticsownersclub.com/tur...oltinstall.pdf
Reply 0
Mar 12, 2008 | 07:45 PM
Quote: what are your current alignment specs. You can have the tires flipped so that the inner tread is now on the outside to prolong the life a little longer. Sounds like a you need a rear camber kit though. The SPC(eibach, ichiba) kits with toe bolts are the most cost effective choices for the rear camber kit.
I havent had an alignment. Should i do that first?
Reply 0
Mar 12, 2008 | 07:55 PM
Quote: I havent had an alignment. Should i do that first?
I would save the time/money and just purchase and install a SPC rear camber kit before the alignment. I'm 99% sure you'll need one. Do you have 350z s-techs or g35 s-techs
Reply 0
