OEM 19" Tires
Old Mar 15, 2008 | 09:55 PM
neal540's Avatar
OEM 19" Tires
Hey guys,
I know a few people run the setup of 275/35-19 on rear tires on the OEM 19" wheels. I was just concerned that it may be too wide for the rim? Is that the case?
Data as per 1010tires.com tire size calculator
Stock Tire - 245/40R19
Section Width: 9.64 in 245 mm
Rim Diameter: 19 in 482.6 mm
Rim Width Range: 8 - 9.5 in
Overall Diameter: 26.71 in 678.43 mm
Overall Diameter: 26.57 in 674.87 mm
Sidewall Height: 3.85 in 97.79 mm
Radius: 13.35 in 339.09 mm
Circumference: 83.91 in 2131.3 mm
Revs per Mile: 778.7
Actual Speed: 60 mph 100 km/h
Tire 1 - 275/35R19
Section Width: 10.82 in 275 mm
Rim Width Range: 9 - 11 in
Sidewall Height: 3.78 in 96.012 mm
Radius: 13.28 in 337.31 mm
Circumference: 83.47 in 2120.1 mm
Revs per Mile: 782.8
Speedometer1: 60.3 mph 100. km/h
Speedometer Difference: 0.526% too fast
Diameter Difference: 0.53%
Any thoughts?
Thanks,
Neal
Old Mar 15, 2008 | 10:00 PM
CandlestickPark's Avatar
ill Sedan
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
bTanz
Oct 15, 2015 02:31 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
mushu
Jul 15, 2015 03:55 PM
