Nitto NeoGen - 245/35/19
Old Mar 24, 2008 | 01:38 AM
  #31
GreenGoblin's Avatar
The goblin resurrection
I have almost 20k on mine and they are showing some signs of death finaly but i was at 2.5 for most of there life.
Old Mar 24, 2008 | 01:39 AM
  #32
Calvin's Avatar
Overglorified Altima
not bad...considering i only got 13k out of my t1r's...and they werent even at -3 the whole time.
Old Apr 2, 2008 | 08:25 PM
  #33
SIN3's Avatar
Originally Posted by minh420
i have been running these for about 15,000 miles and am very happy with them. I do have an eibach camber kit but i still have a little negative camber. These tires in my opinion are better than t1rs because for one you don't have to flip them. From past experiences once you flip a tire it never runs the same. You get more road noise and steering wheel vibrations. I would deifinately buy another set once these go out. They handle great in wet and dry applications.
how low are you? im slammed 2.5-3.0. my tires last about 8-10k. the only way these will last this long is if you have a "sport drop" .5-1.5". pics of your drop?
cal i had the same question. i ended up getting T1Rs again. plus the side way is way to high vs the T1rs. so looks wise its worth the extra money.
Old Dec 2, 2009 | 11:19 PM
  #34
Calvin's Avatar
coming up on 21k miles on -3 camber
Old Dec 2, 2009 | 11:31 PM
  #35
HenryLee's Avatar
What's your tire specs? 245/35/19 and 275/35/19? did you run 255/285 before?
Old Dec 2, 2009 | 11:34 PM
  #36
Calvin's Avatar
first set:
toyo t1r
255/35f 285/35r
second (current) set:
nitto neogen
245/35f 275/35r
i miss 255/285, but if i had 255's up front i'd rub more than i do now. wish i had 285 rears, though. too bad they don't make then in 285's.
Old Dec 2, 2009 | 11:45 PM
  #37
jibberjabbers's Avatar
I had these on my s2k. They have softer rubber in the middle for traction, and harder rubber the outer edges for durability. They aren't directional so you can rotate them if you want to. If they had these in our stock sizes, I would get them.
Old Dec 2, 2009 | 11:47 PM
  #38
Calvin's Avatar
They're asymmetrical. I can't flip them.
Old Mar 21, 2010 | 09:32 PM
  #39
NFSP G35's Avatar
? = 2B || !2B
So Cal, how are the NeoGens? I'm thinking about getting the 245/35/19s for the sedan.
KruZZe
Feb 27, 2023 05:04 PM
jilljann1
Jul 21, 2020 08:12 AM
doublej32
19 Inch
Jan 28, 2016 08:42 PM
Lartytiejdke3
19 Inch
Nov 30, 2015 11:00 AM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
