Need help with offset (spacer needed?) on the rims I'm getting soon
Question with spacer and suspension on the rims I'm getting soon- please help
I've a 05 coupe 6 spd (sport suspension). I'm looking at getting a set of 19" rims that has an offset of +38. the size of the wheels are 19x8.5 in the front and 19x9.5 in the rear. what spacer should i get to set off the car with the best look?
Also, if i want to lower it.. what kind of spring should i go for? i wan to drop it a bit for the best look, but not too low. i see Teins H-tech, S-tech, and Basic. What would be the best set up for me?
Thanks in advance for all the suggestions
well, long story short, there is a set selling on the forum and thinks it's a good deal on the wheels. however, it's +38 so i was wondering what I should do? 10mm?15mm? or higher on the spacer?
really need some help guys.. and any suggestion on the suspension is appreciated.
i'm getting a pretty good deal on the wheels so i thought putting on spacers would solve the problem. is 25mm the best? i have heard so many different suggestions im so confused on what size spacer to get. i have been told 10, 15, 20, and now 25 :/ so confused.
what size of spacer will give me the best "flush: look? is there any website or source i can get such info?
thanks
thanks
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
