245/40r19 vs 255/35r19
Are there any issues with making this change? That stock 245/40 size is only made by a couple manufacturers and they are charging through the nose for that size.
For example. goodyear eagle f1 245/40, $320 a pop. Goodyear eagle f1 255/35, $230 a pop. That's a $90 per tire difference. The only difference I figure is the the 35 tire is about .4" wider and about .35" lower sidewall height.
G coupe lowered on 350z s-techs. I don't think the reduced sidewall height would be any problem and what should be a .2 increase in width on the fender side shouldn't be either.
Any thoughts?
Any thoughts?
ok with those new tires your sidewall will be .4 in shorter and your speedometer will read 2.6% too fast.
not sure if you know about this site, but this is where I got the info. you can try out other sizes also. http://www.miata.net/garage/tirecalc.html
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
vq35dedriver
19 Inch
Jun 14, 2012 05:44 PM
