The G35 Coupe wheel thread to rule them all
OK, I have searched this forum (and a few others) and it appears that wheel upgrading on a G35 Coupe is more of an art than a science. So, here is your chance at immortality... for all those hundreds (or thousands) of future thread-searchers looking for concrete info on offsets, fender clearance, ride height, this can be the place they come to for those answers. If anyone has that info for each year of G35 Coupe please reply. I'll get it started with what I think I know:
2003/2004 G35 Coupe with Brembos and 18-inch wheels
Original Offsets:
Front - +33
Rear - +33
Original Tire Sizes:
Front - 225/45-18
Rear - 245/45-18
What I (and many others) would like to see after the above information, is what wheel/tire combinations honor the original offset (no fender rolling, lines up with outside of car, or ride height/speedo problems) in various rim sizes (18", 19", 20", etc).
If you have an example of wheels/tires you know works (that are on your own car, for instance) mention them! And include pictures!
And let us all also know the impact (if any) of any given offset/wheel/tire/etc on the vehicle's VDC system, ABS, and tire pressure sensors.
If you know the answer to any year Coupe please use the above format and provide your answer... thanks for contributing!
Original Offsets:
Front - +33
Rear - +33
Front - 225/45-18
Rear - 245/45-18
Originally Posted by Easein2itG
I believe SFLG35 already has a thread going related to wheel sizes, offsets, camber and toe.
Here is the link to that thread... (and he started it the same way I started mine - by referencing that he had searched already):
https://g35driver.com/forums/wheels-tires/205511-ultimate-wheel-offset-thread.html
Originally Posted by pdiddy
I found the thread you're referencing but it only contains info on offset of wheels. It doesn't seem to address all the items I listed.
https://g35driver.com/forums/showthread.php?t=205511
Original Offsets:
Front - +33
Rear - +33
Front - 225/45-18
Rear - 245/45-18
Original Offsets:
Front - +33
Rear - +33
Front - 225/45-18
Rear - 245/45-18
https://g35driver.com/forums/wheels-tires/70901-g35-factory-oem-wheel-sizes-offsets.html
Having flush fenders without modifying fenders are two things that don't often go with each other.
There were no significant changes to the coupe until the G37, right? The only difference that would separate 03-04 from 05-07 is Brembo/non-Brembo.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
BlackGee35
Jul 23, 2015 01:36 PM
