Minimum recommended suspension clearance?
Old Apr 1, 2004 | 11:04 PM
dholly's Avatar
Help please. What is the absolutely, positively, tightest recommended clearance between wheel/tire and front suspension for reliable, daily sedan use? I have figured 255/40-18 tire on an 18x8.5 (+43) wheel will result in approximate:
Front suspension clearance of: 0.455" (11.56mm)
Front fender clearance: 0.943" (23.95mm)
Rear fender clearance: 0.943" (23.95mm)
Is that 0.455" OK, or too tight? Also, in addition to wheel and normal tire section width, is it prudent to add a tiny bit more section width (i.e., fudge factor) on account of additional outward sidewall flex when hitting potholes, etc.?
Thanks.
2004 | 6MTs | Diamond Graphite/Graphite
Upstate NY
Old Apr 1, 2004 | 11:22 PM
Gsedan35's Avatar
Re: Minimum recommended suspension clearance?
If it were my car and my dime, I'd take be willing to take it down to those numbers. what would they be for 265/40-18?
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Apr 2, 2004 | 12:15 AM
dholly's Avatar
With the same +43 offset, a 265 adds 0.195" each side for 0.455" minus 0.195" = 0.26" clearance. Too tight for me to order, but a +38 offset essentially leaves the inside edge at the same distance from the suspension (0.454") and moves the outside of the wheel/tire 0.391" further outboard than the 255. Since front fender clearance w/ 255s is about 0.943", that 265 +38 might actually work, assuming the front suspension clearance of 0.455" is sufficient. Either way, I'm still thinking a 255/45-18 on a 8.5 (+43) will go just fine. The calcs are in the will this fit? thread. Gotta make a decision, sale ends soon.
Upstate NY
Old Apr 5, 2004 | 12:20 PM
dholly's Avatar
...any other comments before I kill the thread?
Upstate NY
esotericrider
Northern California
Sep 10, 2015 02:28 AM
Batfinity
Intake & Exhaust
Sep 9, 2015 09:21 AM
Detailed Image
Sep 8, 2015 02:42 PM
socaldavid
Sep 5, 2015 04:35 AM
Detailed Image
Sep 4, 2015 08:35 AM
