Tanabe coilovers?
Old Apr 3, 2004 | 09:58 PM
4080's Avatar
Tanabe coilovers?
Does anyone have Tanabe Sustec coilovers on their coupe? I own a 04' coupe with 20" Maido's and I want the best ride possible without spending over $1000.00. Here it is at stock height...
<P ID="edit"><FONT class="small"><EM>Edited by 4080 on 04/03/04 06:59 PM.</EM></FONT></P>
Old Apr 3, 2004 | 10:01 PM
4080's Avatar
Re: Tanabe coilovers?
Sorry the pic is to big....
Old Apr 4, 2004 | 11:18 AM
Gsedan35's Avatar
Road and track tested a tuner Z that had them on the car, they were not very impressed at all. I'll try and find the article and quote what they said.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Apr 4, 2004 | 01:23 PM
Gsedan35's Avatar
Ok, I found the article from Road&Track. It was a MotoRex 350Z that they tested that had the Tanabe coilovers. They had good things to say about the car until,.......
"The sore spot on the car is the use of the Tanabe coilovers that lower the car significantly and firm up the ride. Certainly the ride is harsher, but that isn't a big problem. It's in corners that are anything other than staking-rink smooth where the car starts bounceing and hopping over bumps, upsetting its balance and occasionally hitting the bump stops. It did understeer the least through slow corners, partially due to its use of the widest front tires 275/35-18 of any of the Z's. The rears were shod with 295/35-18's. It also reacted the best to changes in throttle or the use of the brakes to change the attitude of the car. The Motorex Z showed what a good set of tires will do for a car"
Edmund Burke
G35 6mt
Old Apr 4, 2004 | 06:54 PM
G35Lin's Avatar
Multi-Spoked Mod
hum....i would suggest the Tein Luxury master or the tein regular springs. I heard those are nice and not that expensive. If you really want stock feel, i would suggest the HKS hipermax
Old Apr 4, 2004 | 08:13 PM
4080's Avatar
HKS Hypermax it is. That is sad that this is the only option for a G owner to get a good ride with a lowered stance without buying multiple alignment parts (ex. stillen). Unless someone can convice me that the Tein luxury kit is a better value/ride.
Old Apr 4, 2004 | 09:20 PM
Gsedan35's Avatar
Your forgeting about the Tein CS coilover, it is a system specifically designed for ride quality. Given how it's spring rates do not use lower rear rates, like the HKS LS system does, I'd pick it instead, that is "IF" I was chasing ride quality.
Edmund Burke
G35 6mt
Old Apr 6, 2004 | 11:26 PM
BbyG35's Avatar
Gsedan35...
I've read many of your posts and have come to appreciate your straight forward advice. So that leads me to the following question(s).
I'm considering going with Eibach ProKit on my sedan -- Will they affect my camber to the point where I should be concerned about uneven tire wear? I'm hoping for a little more stability through the corners but not sacrificing the overall ride.
I'm also going with 18x8 wheels which according to my calculations, I should be fine with no rubbing issues -- do you agree??
I'd appreciate your help and usual candid response on this
2003.5 Sedan 6MT, Brilliant Silver
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
