tire pressure monitor light
Old Apr 4, 2004 | 01:29 AM
cynicaL102's Avatar
picked up my car this past thursday.
dealer told me the light goes on at first, but if i drive it around a bit, the tire pressure monitor light would go off. it hasn't gone off yet! anyone know why?
Old Apr 4, 2004 | 09:40 AM
dick's Avatar
Re: tire pressure monitor light
Check your air pressure in the tires.
Old Apr 4, 2004 | 01:44 PM
ABQ_G35's Avatar
Brilliant Silver/Graphite/Chrome Wheels '04 Sedan/5AT
Old Apr 4, 2004 | 06:33 PM
cynicaL102's Avatar
i just got it out from the dealer lot?
you think they messed up on the tire pressure?
i figured since they just gave it to me, it'd be fine
guess i'll take a look at it
Old Apr 4, 2004 | 06:50 PM
Msedanman's Avatar
O.F. Administrator
Always best to check pressures after picking up the ride. Mistakes can happen, and oftentimes do. [img]/w3timages/icons/wink.gif[/img]
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Apr 4, 2004 | 10:23 PM
XIMER's Avatar
hey cynical
i had the exact same problem. my dumb salesperson told me that it was because of the cold air. he said it was because the tire gets compressed or something and that it would get better after couple days. the light stayed on, so i had to take it back to the dealer and they recallibrated the sensors or something. i dont even know what they did with it. good luck
Old Apr 5, 2004 | 01:13 AM
cynicaL102's Avatar
my car beeped at me!
i was driving my car around, and then all of a sudden out of nowhere, there was a loud beeeeeeeeeeeeep sound coming from my dashboard. stopped, then started again, and repeated once more. there weren't any visual warnings. the only thing that shows up on the dashboard was the tire pressure monitor light, but that has been on for the past couple days without a beep. then out of nowhere today it beeped. could anyone know the reason why? my manual is in the car which is in the garage of my apt building and too far to go for it. =P
Old Apr 5, 2004 | 06:58 AM
Thorwolf's Avatar
Re: my car beeped at me!
I think the light comes when the pressure drops to a certain level, then the beeper goes off either when it drops to an even lower level, or a given time passes before filling the tire with air.
<font color=red>2004 G35 Sedan 6MT Desert Platinum/Willow</font color=red>
Old Apr 7, 2004 | 12:00 PM
praztek's Avatar
Mine just did it this morning, but beeped and showed the (!) visual. Have you checked the tire pressure and if so, did it go away?Seems odd, but I just changed out the stock air filter and placed in a K&N and did a alteration to the air filter box,know this couldn't be the culprit, but who knows?
<P ID="edit"><FONT class="small"><EM>Edited by praztek on 04/07/04 09:03 AM.</EM></FONT></P>
Old Apr 9, 2004 | 09:03 AM
praztek's Avatar
Right rear was off, and it took the following day for the light to go away.
Old Apr 10, 2004 | 12:02 AM
ZtoG's Avatar
Mine was going off when the pressure dropped below 35psi. I had a flat, had it fixed, they refilled it to 33psi. I called the dealer to schedule a reset to the system. The service manager said there is no reset, just make sure the pressure is above 35psi on all fours. Filled the left rear to 46psi, the light went off 2 min later.
04' Desert Platinum 6MTCoupe
72' 240z,turbo,intercooled,Electromotive TEC2
Old Apr 10, 2004 | 12:07 AM
WRAH's Avatar
WRAH
That shouldn't be!?!?!
Mine has gotten down to 29psi and no light. At about 26-27psi if when my light comes on.
"What if there is no tomorrow....There wasn't one today!!!" Bill Murray
'04 OB/GL Prem.Pkg./Sport.Pkg/Splash
jsimonk
Dec 22, 2023 03:49 PM
Fireman07603
Aug 9, 2015 06:00 PM
ghost_g35
Aug 7, 2015 10:31 AM
TWASkyliner
Aug 1, 2015 11:43 AM
