Volk GT-7 19" offset question
Old Apr 10, 2008 | 03:43 PM
|| Vitty ||'s Avatar
Am going to be ordering some diamond black 19's for my DG coupe within the next day or so and was wondering what offset I should get for the front wheels. Rears I'm set on 19x10.5+24. For the fronts I notice a lot of people running 19x9.5+30's. Now my question is, could I go more aggressive on the front offset and not have to modify anything on my car? I don't want any rubbing on full lock right/left, and don't want any rubbing due to suspension travel. I may lower the car in the future about an inch tops but for now it is stock. What are your suggestions and what tire size would you then run on the fronts? Thanks for the input guys!
Old Apr 10, 2008 | 03:48 PM
Calvin's Avatar
Overglorified Altima
why are you set on 10.5 +24?
and yes, you can go much more aggressive in the front. the front fenders are already rolled from the factory.
i'd go with 255/35 in the front.
Old Apr 10, 2008 | 04:24 PM
|| Vitty ||'s Avatar
I'm set on 10.5 +24 because I don't want to roll the rear fenders at all and I understand that is a safe bet. As far as fronts, what offset would you then recommend?
Old Apr 10, 2008 | 04:50 PM
jdmgee35's Avatar
+15! Like Calvin said, fronts are already rolled, so u'll be fine. Just prepare to drive with a bit of camber.
Old Apr 10, 2008 | 04:55 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Depending on your drop, a 10.5 +24 will still rub even if you dont go with the wider 285/35 tire over the 275/35.
As far as the fronts go, you can do as much as a 9.5 +9 with a 245/35 tire and slam the car and you still wont rub even with the wheel at full lock
Let me know what the car is dropped on and how much camber you have and i can be of further assistance to you.
-GP-
Old Apr 10, 2008 | 05:09 PM
Calvin's Avatar
-GP-
+1 I had to cut my fenders and my wheels are 10.5 +25 with 285/35 tires in the rear.
Old Apr 10, 2008 | 05:27 PM
|| Vitty ||'s Avatar
-GP-
So far I'm riding stock height. Was planning on installing some springs(probably eibach pro kit) with a max drop of 1.1" front and 1" rear.
Old Apr 10, 2008 | 05:28 PM
|| Vitty ||'s Avatar
Hey man, did you ever get any more pics of your car taken?
Old Apr 10, 2008 | 09:23 PM
jdmgee35's Avatar
sorry for the lag, as soon as i take some new, better shots, i'll be sure to post them up.
Old Apr 10, 2008 | 11:39 PM
Alteus's Avatar
So from this thread, is it safe to assume that a 19x10 +22 will fit all around without having to roll fenders, running 255/35? Car has about a 1.5" drop on tanabe coilovers...
Old Apr 11, 2008 | 12:23 AM
GLuXuRy's Avatar
dang i forgot what zackt69 is running .. but for tires i believe he is running 245/35 and 275/35
just take it this way .. go aggressive .. and if the wheels dont fit where your camber specs are at .. you go smaller tire and more negative camber .. then a rear fender roll .. and your ready to roll
Old Apr 11, 2008 | 01:27 PM
|| Vitty ||'s Avatar
I guess my only options for fronts are 19x9.5+30 or 19x9.5+17. I'm thinkin +17 and run 245/35's. I should be fine right??
Old Apr 11, 2008 | 02:59 PM
|| Vitty ||'s Avatar
Well I hope I'm fine cause thats what I ended up with haha. 19x10.5+24 rears and 19x9.5+17 fronts. Can't wait!
Old Apr 11, 2008 | 03:48 PM
Calvin's Avatar
you'll be fine with 9.5 +17 245/35
Old Apr 11, 2008 | 03:59 PM
|| Vitty ||'s Avatar
sweet thanks for the info
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
neight
Aug 3, 2015 11:27 AM
