good or bad idea for tires
Old Apr 11, 2008 | 01:44 AM
imjackiechan's Avatar
Cool good or bad idea for tires
Does it matter if you get all the same tire brands for front and the back? like if i had falkens in the front and like saaayyy toyos in the back?
Old Apr 11, 2008 | 02:44 AM
Triple8Sol's Avatar
You'll be fine, as long as you get the proper sizes.
Old Apr 11, 2008 | 07:26 PM
aight kool thanks you
Old Apr 11, 2008 | 07:41 PM
tdm racer's Avatar
Different tire designs and tread compounds could cause unusual handling characteristics like over steer or understeer tendencies. It's probably better to get the same brand and model tire on front and rear for optimal handling.
But, If money or availability is a problem, so long as you're not pounding the car or auto-xing then most people won't feel the difference.
Old Apr 11, 2008 | 07:44 PM
hmm i c
Old Apr 11, 2008 | 07:55 PM
RRG35's Avatar
If you want to save money in tires just go to:
Tire Central
5132 Walnut Grove
San Gabriel, CA. 91776
626-698-1182 talk to Donald tell him renzon from G35 driver forum send you He will hook you up.
Old Apr 11, 2008 | 08:00 PM
OMG serious? THAT WOUD BE EPIC ...! thank you.
and do they only sell tires? i need some 15mm spacers for the back and
20mm for the fronts
Old Apr 12, 2008 | 10:35 PM
Beebo's Avatar
you will be fine as long as they have the same performence ratings... i had toyo t1rs in the front and falken 452s in the rear and all was good
Old Apr 13, 2008 | 06:00 PM
kool thnx
Old Apr 22, 2008 | 04:52 PM
emtguy05's Avatar
Tire Central
5132 Walnut Grove
will he hook me up if i live in San Diego?! I need new tires all 4 of them
Old Apr 22, 2008 | 04:53 PM
MixturePinoy's Avatar
you also want to make sure that tread patterns are similar
Old Apr 23, 2008 | 12:24 AM
Beebo's Avatar
^+1...
Old Apr 23, 2008 | 01:14 AM
what does the ^+1 mean
Jusseth
Sep 13, 2020 12:25 PM
hdmark
Apr 29, 2019 04:31 PM
bTanz
Oct 15, 2015 02:31 PM
itschuckster
Jul 25, 2015 08:07 AM
