Will it matter if I put a 235/35-19 on this rim....Help Appreciated
Old Apr 13, 2008 | 12:21 AM
nchima's Avatar
The fronts are 19x8.5 with +23 offset...I have 245's on them now....I also want to get spacers, want to push them out just a tad. Recommendations Appreciated
Please provide information
THANKS!!!
Old Apr 13, 2008 | 12:46 AM
tyb's Avatar
tyb
I have very same offsets on the GTV's and I'm considering the same tire size...I believe that this option will produce the "stretch tire" look.
Old Apr 13, 2008 | 01:01 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
It will be somewhat stretched, but not too stretched. A 235 will work fine on an 8.5" wheel. You're gonna want 25mm spacers if you want to flush it out all the way (if you're dropped any significant amount.)
-GP-
Old Apr 13, 2008 | 01:08 PM
nchima's Avatar
thanks any links to spacers...
Old Apr 13, 2008 | 02:24 PM
Beebo's Avatar
H&R makes a good spacer
Old Apr 13, 2008 | 02:34 PM
gary c's Avatar
Tire question....?
Why would you put a smaller tire on your frontend? 235s can't be that much
cheaper than the 245s you currently have. There's a fine line between what
might look cool and what works best for you car. Having been in the Brake/
Alignment business spacers are not a good idea either....wheel wobble and
alignment issues are enough for me to stear clear....sorry my two cents!
Old Apr 13, 2008 | 03:23 PM
nchima's Avatar
I gotcha man, yea I probably will steer away from spacers but the price is almost 250 bucks savings between the 235 and 245 tires.
Old Apr 13, 2008 | 03:26 PM
Hubcentric spacers, such as H&R and Ichiba will not produce any wobble and have no affect on the alignment of the car.
-GP-
Old Apr 14, 2008 | 12:11 AM
Triple8Sol's Avatar
235 will be out of spec. So, the answer is yes, it matters.
Old Apr 14, 2008 | 01:19 AM
GGRJR's Avatar
A 235/35-19 will be fine on an 8.5 inch rim. I am currently running a 235-45-18 on an 8.5 rim, with no issues. I did a little research and Bridgestone lists 8 to 9.5 inch rim as acceptable
http://www.tirerack.com/tires/Spec.j...335YR9RE050AN0
Hasanbaloch
Feb 29, 2024 08:45 PM
jsimonk
Dec 22, 2023 03:49 PM
Phenomenon9
Aug 9, 2015 01:34 AM
Jadenkid22
Jul 14, 2015 12:33 AM
