Rim stained?
Old May 10, 2008 | 01:14 AM
blueboxer's Avatar
Clearcoats on Ray/Volks/Works etc.. are very delicate and even car soaps let alone brake dust, grime you pick up while driving, and the like can burn right through the clearcoat. Once that happens you are pretty much stuck with getting them polished or re-coated. You can try vinegar and water at about 50/50 to remove any chemicals that have not burned through the clearcoat entirely.
If you are going to invest in nice wheels you should also invest in a quality wheel cleaner and sealant to protect your assets. I would avoid ever using a drive through wash or any place that does not completely handwash your vehicle and is not willing to keep your wheels away from their chemicals.
Solid wheel soap/washes:
P21S
http://www.detailedimage.com/wax.php...l-Cleaner-P86/
Chemical Guys- I have used most of their products and they are among the best. I have not used this one because I still have the above left, but it is next on my list.
http://www.detailedimage.com/wax.php...-Cleaner-P179/
Wax/Sealent- you protect the finish on your paint, do the same for your wheels
http://www.detailedimage.com/wax.php...l-Sealant-P40/
Old Jun 3, 2008 | 08:50 PM
rjm805's Avatar
http://WheelRevivers.com can bring the factory finish back. Serving So Cal (858)-431-9899
dseet
Oct 11, 2015 12:40 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
johnadlertech
Interior
Sep 4, 2015 12:26 PM
