Falken 452 & VDC
Falken 452 & VDC
Just mounted 2 new Falken 452 255/40/19 tires in the rear, prob have 60-70 miles on them. On my way home from work there is a nice sweeping turn coming off of the highway that is fun. So today I wanted to see how the new tires felt and quickly in the corner the VDC light came on. Any ideas?
Sure hope this is not permanent.
Meh. . .again with the "why does my VDC light come on in long sweeping corners?" Is your brake fluid low? If it sloshes and goes below the acceptable minimum, VDC will flash and then stay on. Did you skid at all, triggering the VDC to come on?
I know exactly what you mean..I get the same thing too.
Everytime I'm entering the freeway on a downward curve...my left front wheel kicks VDC in..and it actually makes my front end swerve over..it's a bit hard to describe. tires are 90%..fluid is fine...it just gets annoying having to turn VDC off everytime I want to do some spirited driving.
mine is pretty sensitive and i have falkens all around... maybe b/c i've been to the track a few times and know how much skid is acceptable (in terms of my driving). just turn your VDC off... hopefully you're not driving around "spirited" all the time
06g35
Feb 14, 2022 05:59 AM
Thebaws11
Nov 30, 2016 12:54 PM
