read the FAQ, but will these still fit?
Old Apr 25, 2008 | 12:32 AM
G'd-up's Avatar
The tire sizes are 245-30-20 in the front and 285-25-20 in the rear. The rims are 20x9.5 and 20x10.5.
Old Apr 25, 2008 | 12:48 AM
SxExCx's Avatar
yes
Old Apr 25, 2008 | 12:57 AM
G'd-up's Avatar
without rolling fenders? in the faq it said 10 but what about 10.5? just wanna make sure before i buy them. By the way its for an 03 sedan
Old Apr 25, 2008 | 01:06 AM
(>")> G35's Avatar
Should be able to fit them on the sedan, but the offsets and camber is going to be very important in order to get them to work. With 9.5" front you'll need about a +35 to clear the knuckle and 2-2.5 negative camber to them back under the fender. The rear you can probably run a +45 offset with rolled fenders and again some negative camber. You'll need smaller tire widths too.
Old Apr 25, 2008 | 01:10 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
You cant fit it with those tire sizes. First off, you'd need atleast a 2" drop and -2.5 camber all around. The offsets would have to be around +30F and +40R with 235/35F and 255/35R tires, and you'd need to flatten the rear fenders.
-GP-
Old Apr 25, 2008 | 01:24 AM
G'd-up's Avatar
thanks a million guys it really helped. i knew the front would fit, but the rear was pretty close call, so i wasnt sure.
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
rsingerG35
Accessories
Mar 16, 2016 01:41 PM
g35Serge
Sep 30, 2015 11:43 PM
yassy
Aug 9, 2015 07:31 PM
