2006 G35 sedan wheel help!
Old Apr 27, 2008 | 08:23 PM
satanklawz's Avatar
Will 20" wheels with these specs fit my 2006 G35 sedan? If not why?
Size: 20x8.5 Front 20x9.5 Rear
Bolt Pattern: 5x114.3 or 5x4.5
Offset: +20mm
Centerbore: 74.1mm
Old Apr 27, 2008 | 08:50 PM
absolutg's Avatar
workin...
offset is way too low for a sedan
Old Apr 30, 2008 | 09:59 PM
satanklawz's Avatar
ok so what will be the problem if I try to put them on the car? Would a spacer or adapter that will push them out to 35-40mm fix the issue?
Old May 1, 2008 | 02:30 AM
G SEDAN's Avatar
problem is that.....at a low offset you are already sticking out.....so if you get spacers...they will stick out even more....with that set up you should be looking at about +38mm offset max...any more will require mods to fit on your sedan
Old May 1, 2008 | 02:34 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
It CAN be done... but there is quite a bit you need to make it happen.
First off, you need to be willing to stretch your tires
You'd need:
225/35/20F
245/35/20R
Secondly, your car MUST be dropped atleast 2 inches front and rear.
Third, you need to have atleast -2.0 degrees of camber.
And dont forget about rolling the fenders, it's a must!
-GP-
Old May 1, 2008 | 07:30 AM
satanklawz's Avatar
not worth it, I will find different wheels.
arora_g35
Apr 16, 2026 02:52 PM
nickmcc123
Lights
Oct 7, 2017 12:18 AM
laksjd84
Jul 24, 2015 05:12 PM
BlackGee35
Jul 23, 2015 01:36 PM
ResoG35Sedan
Jul 14, 2015 10:30 AM
