High offset help!
Old Apr 28, 2008 | 10:49 PM
LukesInn's Avatar
Question High offset help!
Hi, I was wondering what would I need in order for these rims to fit? They are front: 8.5"width +40 offset rear: 10"width +45 offset. What kind of spacers will I need, will I need to roll the fenders and extend the lugnuts? Is it worth it to work with this type of situation. I also have rotora BBK all around if that is a factor, and my car is pretty low, and kitted out. Thanks in advanced.
Old Apr 28, 2008 | 10:54 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
assuming you have a coupe, you'll need 25mm spacers front and rear, but even with 255/285 tires it wont be fully flush. Unless you're getting a really good deal on the wheels, i'd wait, save up your money, and get wheels with the right offset.
-GP-
Old Apr 29, 2008 | 01:30 AM
undefeated350gt's Avatar
+1. I got my wheels for a steal and the guy sent me some 40 offsets in the rear (19x10 +40). I had some help from redlude and now with 30mm spacers, it brought my overall offset to +10. I am happy with that. You will prob. have to use spacers anyways because of your bbk, i doubt those wheels are custom.
just do the math what ever spacer you get, subtract the offset of your wheel from that number.
so 45mm ofst and a 25mm spacer will only yield a 20mm offset so that should be sufficient if your looking for a flushed look.
What type of rims are they?
Old Apr 29, 2008 | 05:13 AM
Triple8Sol's Avatar
With those offsets/widths, I'd want to run 30mm spacers front & 35mm rear. That's not even super aggressive, either.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
TurTLe*
Sep 29, 2015 01:43 PM
