will it clear
Old May 2, 2008 | 01:48 PM
obby's Avatar
will it clear
Will 19x10+34 SSP SP1 clears the front with Brembo brake, and will it be tuck, or pretty flush with the fender. Tire im planning to run are 255/35/19. I currently Have 19x10+25 SSR SP1 in the rear right now and it’s perfect with 285 in the rear. Also will the lip be bigger on the +34 offset, versus +25offset.? Wheels came off my 350z which was running 19x10+25 all around with non brembo brake, and thought I could fit it on the G35. I really love the wheels but im having a hard time finding just 2 wheel for the front. As if right now I can only get my hand on 19x10+34 that’s in stock and ready to ship to me ASAP. Thanks for the help.
Old May 2, 2008 | 03:32 PM
redlude97's Avatar
I don't see that ssr's spec sheet anywhere. Are you sure thats the offset?
http://www.more-japan.com/SSR/sp1/19inch.php
Old May 2, 2008 | 03:47 PM
obby's Avatar
my bad i believe it was +37
Old May 2, 2008 | 03:52 PM
redlude97's Avatar
There are 2 19x10+37's, you need to find out which center disk it uses. You need a high pad to clear brembos, neither of which those are, so you will have to run spacers. The +37 also stands a good chance of hitting suspension components on the inside. If that is a 19x10+37 with a normal pad center disk, then I would run a 15mm spacer. If its the 19x10+37 super low center disk, it will not work at all
Old May 2, 2008 | 04:00 PM
obby's Avatar
thanks allot bro.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
