Heya, I have OEM coupe 19s. I want to make it look a little more aggressive by putting some wheel spacers on. I also plan to have these spacers with non-springmounted 350z H-Tech springs. What size wheels spacers should I buy, and what brand? If it helps, I have not and do not want to roll my fenders. Will it make my G look lower if I push out my rims with the drop from the H-Techs?
Also, where is the cheapest place I can find these parts?
Muchisimas Gracias,
Kevin (:
Muchisimas Gracias,
Kevin (:
Thanks for the quick reply, Strtsk8r321.
Anyone else can confirm or have different input? Any contribution is greatly appreciated.
Beebo
close
- Join DateDec 2006
- LocationEl Paso Texas
iTrader Positive Feedback98
iTrader Feedback Score(59)
Liked:205 Times in 182 Posts
i say 15mm front/20mm rear... H&R Spacers
From what iv read the H-techs dont settle much in the rear so no need to roll...
now if you go 20/25 then id roll...
Thanks for the reply, Beebo.
After much thought, I think I'm actually going to go with the springmount mod.
Should I go with the 15mm front/20mm rear, then? Any big differences between H&R & Project Kics wheel spacers?
And where can I find these spacers? So far, I haven't found any vendors in the marketplace and I'm pretty sure I've searched most of the forum sponsors for these things...
Anyone else have any input they'd like to share?
I am currently running the H-Tech w/ spring mount mod and D-specs (although your shock type does not matter).
I can tell with 100% certainty (and more than 40,000 miles) that you will have no issues with 15mm spacers front and 15mm spacers rear. This set up allows you to go as large as 275/35/19 in back and 245/35/19 in front with no rubbing.
Now for my opinion...
I think the 15mm spacer looks perfect. Go wider with caution, you will cheapen the look of your ride if you have skinny tires extending pasty the fender well.
https://g35driver.com/forums/showthr...t=chriscollins
that's my car with OEM 19's, 25mm spacers front and back, lowered on Tein S-Techs (For the 350z).
Just in case you were wondering what 25mm front AND back looks like.
i have no rubbing issues.
-chris
-chris
Thanks for the info, ResIpsa. Originally Posted by ResIpsa
I am currently running the H-Tech w/ spring mount mod and D-specs (although your shock type does not matter).I can tell with 100% certainty (and more than 40,000 miles) that you will have no issues with 15mm spacers front and 15mm spacers rear. This set up allows you to go as large as 275/35/19 in back and 245/35/19 in front with no rubbing.
I can see what you mean by that cheap look. Have any pictures of your car to show me the drop/how flush your tires look with your fender?
-chris
Car looks good with the drop, chris. It's a bit comforting to know that you don't rub despite the fact that you lowered your car more than H-Techs would with those S-Techs and you used some pretty big spacers. From the pictures, I don't see any "cheap" look that ResIpsa was talking about.Originally Posted by chriscollins
https://g35driver.com/forums/showthre...t=chriscollinsthat's my car with OEM 19's, 25mm spacers front and back, lowered on Tein S-Techs (For the 350z).
-chris
Any others want to share their opinion? I'm just trying to gather as much information/opinions on this before I bite the bullet.
Beebo
close
- Join DateDec 2006
if you get the spring mod go 15/20...Originally Posted by xx7sephiroth7xx
Thanks for the reply, Beebo.After much thought, I think I'm actually going to go with the springmount mod.
Both are good spacers from what iv read
^ Yeah, I think that's what I'm going to do.
I found a link to a site with Project Kics spacers (so far I have yet to find a site that has them?):
http://www.autornd.com/catalog/produ...3055914be98623
My last two questions are: I should purchase the hubcentric ring, right? How is the price on these Kics?
Yes definitely get the hubcentric ring. Project kics have built in studs opposed to extended ones. 15/20mm is being a little conservative and 20/25mm would be more flush. I've seen lots of pictures and it looks good with that setup (not cheap looking). Thats what I was going to do with z h-techs & springmount mod before I got new rims.
06 coupe dropped on 350Z S-Techs
Got these:
http://cgi.ebay.com/ebaymotors/ws/eB...m=350056300060
I have been looking at them for a while and wondering if they were for real since they are about half the price of retail.
Finally decided it was worth a shot and I was not disappointed. Excellent machining and hubcentric rings are included. Perfect fit, no margin for play. A 90mph run on the freeway after install and I am happy to say no vibration at all.
I went 20mm all around. I was going to go 20/25 but with the 350z s drop I was worried I would have to roll the rear fenders. I think I made the right call. no rub and it looks like it clears by only a couple millimeters.
Got these:
Quote:
Alright, I'll definitely do that then. Project Kics look like the wheel spacers I'm going to get, along with hubcentric rings. They're just "plug & play," right? As in I take off the wheels and slide on the spacers & rings? No hammering out of old studs and installation of new ones?Originally Posted by Strtsk8r321
The only thing I'm unsure of is how big the spacers will be. I'm getting contradicting opinions here. haha.
Quote:
Much appreciated, thanks! Really want to see them.Originally Posted by resIpsa
I'll post some pics a little later
Quote:
Got these:
Hmm, thanks for that ebay link, but I think I'm still going to go Project Kics. I'm a little bit of a brand *****. Originally Posted by EncoreCestMoi
06 coupe dropped on 350Z S-TechsGot these:
20mm all around? That's what I was thinking. I think 15mm is a bit too conservative, and 25 might be too much. I think 20mm will be the right size. I just need pics to justify it!
Thanks all, for your responses. Anyone else have any input?
If i do the Kics 15mm(front/20mm(rear) S-tech springs, and SPC camber kit. Will i still be okay to Auto Cross? I don't want any problems when i race. Thanks in advance.
