275/35 or 275/30 in the rear?
Originally Posted by JOKER
275/30 sidewall is 3.2 inches
245/35 sidewall is 3.3 inches
Sound bout same to me.
The 30/35 indicates that this tire size's sidewall height (from rim to tread) is 30/35% of it's section width.
245/40/19(OEM rear size)=26.7" diameter
275/30/19=25.5" diameter
over 1" shorter than stock, does that still sound the same?
and your pointing this out why?
why do you say that? Going with the smaller size in the rear will mess up the weight distribution and can cause weird handling characteristics due to the front tire being taller than the rear. 275/30/19 IMO should never be used on the rear of a coupe. Stick with 275/35/19
That's why
And his front is not 245/40
What does that have to do with aspect ratio's? Everything I've stated is true. I know how aspect ratios work.
You don't get it, the stock tire sizes have a height stagger front to rear. the 275/30/19 rear not only eliminates this, but it reverses it by making the front taller than the rear. This will change the handling characteristics of the car.
Sidewall: Front 4.4 Inches Rear 4.6 Inches
OEM 18 Inch: 225/45R18; 245/45R18
Sidewall: Front 3.9 (almost 4) inches Rear 4.3 Inches
OEM 19 Inch: 225/40R19; 245/40R19
Sidewall: Front 3.5 Inches Rear 3.8 Inches
OP Setup: 245/35/19; 275/35/19 or 275/30/19
Sidewall Front 3.3 Inches Rear 3.7 Inches or 3.2 Inches
With 275/30 rear is 0.2 lower then front. That is 2 tenth of an inch.
It is not enough to offset any weight balance or airflow.
On the track it will only be positive factor due to a smaller sidewall and less tire play.
OEM 17 Inch: 225/50R17; 235/50R17
How is it not enough to effect weight balance? The car goes from having a raked stance to a sagging rear. Not to mention gearing changes and possible VDC issues. Any way you cut it, 1.2" shorter overall diameter in the rear compared to stock will change the way a car handles
1.2 will 0.2 will not
You still don't get it. You have to compare the height to the stock size, not the front size. The stock tire sizes are 225/40/19 and 245/40/19, an ~1" height stagger, the 245/35/19 matches the 225/40/19 diameter pretty well while the 275/30/19 doesn't even come close to matching the rear size. The front and rear tires are NOT supposed to have the same diameters.
Look at all this diff sizes
Joker, you lose on this one, you somewhat have an understanding, but you're failing to see the bigger picture. Even if you look at the 275/30, compared to the 245/35 front, the front is still greater in diameter than the rear which should NEVER be done. Sidewall height makes no difference as long as the diameter in the rear is greater than in the front (just how it comes from the factory)
-GP-
-GP-
-GP-
-GP-
You'll never notice that.
Anyways. With todays gas prices you want to go taller and thinner
#30
