overall diameter question...
ok so 2 questions...
a) since the front tires have nothing to do with the drivetrain, does it matter if the overall diameter chances??
b) what are the consequences of running a bigger diameter tire in rear? smaller? (the diff is +/- 1" off the diameter of the oem tires)
tia
vick
tia
vick
The consequences, as I understand them, are that the VDC doesn't like changes in diameter over a certain amount, what that percentage is I don't know. Many have run smaller or larger than OEM with no problem. 1" larger diameter should pose little problem.
The obvious thing is the speedometer will no longer be accurate it may be close though. Smaller tires will cause you to rack up more miles on your car and hurt your fuel milage slightly as the tires will do more revolutions per mile than OEM sizes. The larger will have the opposite effect. Stick as close to oem size as you can small changes will only have very minor effects that will not be that noticable. If you look around you can find a wheel size calculator that will tell you how much your speedo is out.
One inch overall increase front only will almost certainly cause issues on cars with VDC. A fair amount of Z's did not have VDC, just TCS, that's why you see more same-size all around sets on Z's.
Check my350z top 100 questions, details on sizes there apply to G35 Coupes for right-sizing, too.
Last edited by SteveZ; Jul 7, 2008 at 03:25 PM. Reason: clarification - diameter vs. circumference
Just say no
Read my two posts here:
https://g35driver.com/forums/wheels-tires/230051-tire-wheel-upgrade-affect-mileage.html
BlueBelleG35x
Jul 23, 2015 02:10 PM
