Is the SEDAN offset and COUPE offset the same???
May 24, 2008 | 04:21 PM
Will aftermarket wheels that fit a sedan fit my 04 Coupe (no brembos)??
Reply 0
May 24, 2008 | 04:22 PM
offsets are not the same.
what kind of rims? they should fit since you dont have brembos.
Reply 0
May 24, 2008 | 04:34 PM
they will most likely be sunken in. gonna need spacers
Reply 0
May 24, 2008 | 04:40 PM
they're giovanna's
Reply 0
May 25, 2008 | 02:23 PM
Hasn't anyone run into this problem before??
HELP ME OUT IF YOU KNOW FOR SURE
Thank you..
Reply 0
May 25, 2008 | 06:33 PM
they should be the same or close to it.. Seeing how the OEM 19" rays fit perfectly on the sedan..
Reply 0
May 25, 2008 | 06:35 PM
^^^ you are STUPID
Reply 0
May 25, 2008 | 06:36 PM
The OEM rays are +30 and +33 offset - very good for the sedan. They're tucked on the coupes for that reason. Usually on the coupe something right about +20 is a flush offset.
OP, what is the offset of your wheels?
Reply 0
May 25, 2008 | 07:04 PM
Chip, there's a sticky that shows the OEM offsets of each vehicle. Yes, similar wheels will usually work, but the fitment will be different. If you want to know what effect they will have for you, compare stock to your desired wheel using this:
http://www.1010tires.com/WheelOffsetCalculator.asp
Reply 0
Dec 16, 2010 | 08:41 PM
Bringing back an old thread for help..
I'm looking to run sedan 19"x8.5, +45 offsets on my 03 coupe, non-brembo..
What would be decent spacers to use for rear and front? Just for about a stock/flush fitment..
Thanks guys.. much appreciated
Reply 0
Dec 16, 2010 | 09:13 PM
30mm will bring it to +15 which is a nice look. Personally 0 is the furthest I'd go. You'll need to roll your fenders and have some - camber
Reply 0
Dec 16, 2010 | 09:51 PM
isn't stock coupe about +30?
Reply 0
Dec 16, 2010 | 11:30 PM
^^ See post #8.
Reply 0
Dec 17, 2010 | 12:17 AM
My bad.. thanks
Reply 0
