New Wheels????
Old May 28, 2008 | 12:36 AM
FlyingLumpia's Avatar
I am really shocked that the wheels dont fit over the brembos. They must be bigger than I thought they would.
Old May 28, 2008 | 12:40 AM
snavematt's Avatar
just a sedan
I dnt know if it is because they are GT series, but they are huge
Old May 28, 2008 | 03:49 AM
ttrank's Avatar
Grocery getter
What about a pair of +40 Sevas to match the rears? If you ran a 15mm spacer on the front would they clear? How much to they need to come out to fit?
Old May 28, 2008 | 09:19 AM
snavematt's Avatar
just a sedan
Only the rears come +40, and I dont want that huge lip in the front. I will check with Sevas again, but I think the 1 piece are all the same, forged may be this way
Old May 28, 2008 | 10:55 AM
ttrank's Avatar
Grocery getter
Not true, they both come in +25 and +40.
+40 has a smaller lip. As the offset gets higher the face of the wheel is closer to the edge. This will give you more space for your brakes.
Old May 28, 2008 | 02:08 PM
So Tim you saying that the +25 will have a bigger lip than the +40. Man maybe I should buy one of those will and put them in the rear for the wannabe staggered look.
Edit: Btw way, if they dont fit with a +25, I dont think they will fit with a +40 and a spacer. Because with a +25 it pushes the face away, and the +40 will be closer in. So even with a 15-20mm spacer it will still be to close. Correct me if I am wrong.
Old May 28, 2008 | 02:51 PM
G SEDAN's Avatar
The +40 sevas have a smaller lip so the face is further away from the hub thus creating more clearance. If the +40 doesn't clear, he can still adjust with spacer and will give him more space than it would with +25, he's just giving up the lipage.
Old May 28, 2008 | 04:05 PM
snavematt's Avatar
just a sedan
Ok, I will get a measurement for my brakes and for the sevas, so try a +40 in the front.
Old May 28, 2008 | 04:43 PM
ttrank's Avatar
Grocery getter
Yeah, get a measurement and see how much room you need. You should be able to send that to Sevas and find out if the +40 S22 will clear.
Old May 28, 2008 | 05:15 PM
How much more of a lip does the +25 have. I cant see it being a big difference. Sorry for jacking your thread.
Old May 29, 2008 | 11:45 AM
ttrank's Avatar
Grocery getter
I would guess 10-15mm
Old May 29, 2008 | 12:12 PM
(>")> G35's Avatar
It's generally true that lower offests have more lip on multipiece wheels, but it's not the case most of the time when it comes to 1 piece wheels.
Old May 29, 2008 | 01:14 PM
ttrank's Avatar
Grocery getter
I know the Sevas 10" +25 have more lip than the +40's, I have seen them side by side.
Old May 29, 2008 | 02:22 PM
snavematt's Avatar
just a sedan
I think will just not go with the Brembos, too much work to figure all this out. I dont know, Im frustrated
Old May 29, 2008 | 06:40 PM
  #30
ttrank's Avatar
Grocery getter
It would be worth it in the long run...
I would keep them!
