19" VS-XX Offsets G35 Coupe
Old May 27, 2008 | 11:42 PM
sevret.t's Avatar
I'm planning to get some 19x9.5 Fronts and 19x11 Rears for my g35 coupe, im looking for an aggressive offset, i dont mind rolling my fenders and stretching my tires a bit, will be riding on hks hiper max 2's dumped low. what offsets are you guys running with that size rims with a large drop?? any advice?
Old May 28, 2008 | 03:15 AM
Calvin's Avatar
Overglorified Altima
9.5" -12 w/ 25mm spacer (front), 11" +6 (rear)
https://g35driver.com/forums/media-share-g35-coupe-v35/207862-my-new-vsxxs.html
Old May 28, 2008 | 04:01 AM
ttrank's Avatar
Grocery getter
Ohhh so nice!
Old May 28, 2008 | 02:36 PM
sevret.t's Avatar
how much cutting would be required to fit that offset onto my car? i dont mind rolling and cutting, but im i've never had to stretch my tires so much im new to it, my last car (S14) had a stretched tire but wasnt so stretched as the ip g35, im game for it but any advice?
Old Jul 6, 2008 | 08:40 PM
sevret.t's Avatar
how about 19x9.5 +7 fronts and 19x11 +13 for the rears? what do most coupes run?
Old Jul 7, 2008 | 03:41 PM
SIN3's Avatar
thats a real nice fitment there. but most coupes run offsets in the high 20s to low 30s because they like "meatier" tires or afraid to rub. DO ET
Old Jul 11, 2008 | 03:11 PM
sevret.t's Avatar
planning on gettin them within the next month or 2..
Old Jul 11, 2008 | 03:25 PM
MIA BlazinVQ's Avatar
brb getting cut
I have 9.5" +21 up front and 11" +23 in the rear dropped on 350Z S-techs. Not agressive but it isn't tucked at all (at least the rears not at all).
Old Jul 12, 2008 | 08:29 AM
sugsss's Avatar
^^^no cutting needed just roll the rear's flat,if your going to dump it(like no finger gap) then those offsets will get you a flush almost poke look going gl.
side note:if you aint rubbing you'r not looowww enough muauauauauauauhhhhh!!!!!!!!!! ,sorry to much alcohal
Old Jul 22, 2008 | 05:15 PM
EEjiggapin0's Avatar
I had this same question, what size tire would you need in the rear not to rub with the 19x11 +13, and also the rears are rolled flat...
Old Jul 22, 2008 | 05:18 PM
redlude97's Avatar
285/35/19 should work for most tires, and 275/35/19 for some of the meatier tires
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
