HKS Hypermax vs. II?
Old Apr 18, 2004 | 04:47 PM
4080's Avatar
What is the diff. between the HKS Hypermax Ls coilovers vs. the Hypermax II. If I buy these will I need any adjustable camber or tow-in parts? I do not want to spend $1800.00 on coilovers plus another $800.00 for all the crap to get the car aligned. My car is an 04 coupe with 20" Maidos.
Old Apr 18, 2004 | 07:56 PM
bkchang79's Avatar
Re: HKS Hypermax vs. II?
no coilovers for the G35 come with alignment pieces. The LS is tuned for ride quality and the II is for track.
2003 G35 Coupe 6mt Diamond Graphite
AIM= bkchang79
Old Apr 19, 2004 | 12:09 AM
Gsedan35's Avatar
Three things to know about the LS system. One, it's designed to offer up a like stock ride quality. It is not designed to impress the performance minded. Second, it shift's the spring rate balance of the car to the front, so a car with them will understeer more should you be inclinded to push it to the limit's. Spring rates front 448lbs rear 336lbs ='s F+43% R -2% Transfer's 45% roll stiffness to the front! Secondly, the dampners cannot be adjusted, but the LS+ version does have that.
The Hypermax II are sprung and valved for performance street, with 504lbs spring rates front and rear. The front to rear balance is also a lot better, F+60% R+47% ='s transfer of 13% roll stiffness to the front, but difference to the LS which transfers 45% to the front.
If in the market for a comfort type coilover, I'd pick the Tein CS before I'd go with the LS.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Apr 19, 2004 | 03:07 PM
nismoGcoupe's Avatar
does anyone have any info on the new model coming out in May i think there called HKS Hypermax RS
Crisci33
Jun 29, 2017 08:31 AM
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
