Spacers & Tires
Old May 29, 2008 | 02:26 PM
hanguk9117's Avatar
Spacers & Tires
I've searched through the forums, and read multiple threads on spacers for OEM 19's (Coupe). It seems like at first, people were recommending 15mm (front) & 20mm (back), with a few suggesting 20mm (front) and 25mm (back). But then there were a couple people that went 25mm all around and posted pictures of their set up, which looked awesome.
I'm planning on keeping my OEM 19's, and lowering my Coupe on Z H-techs. Just looking for confirmation that the 25mm all around will NOT cause any rubbing even with sharp turns, going over bumps and what not, with this setup. It seems like they would be okay since the Z H-Techs are a mild drop, but if they will cause rubbing...what would be the widest I can go w/o any rubbing (and w/o me having to roll my fenders)?
Thanks peeps.
Old May 30, 2008 | 07:04 PM
hanguk9117's Avatar
can ne1 w/this setup confirm?
Old May 31, 2008 | 02:23 PM
LightsOut's Avatar
SIETESG
i have 15 20 set up on my stock 19's
after looking at mine, you can go 25 but if you plan on going with the spring mount, plan on rolling your fenders.
the front you can put 20 or 25 size spacer but if you plan on going wider tire i suggest staying with 15 size spacer.
i wouldnt do 25 wouldnt look right in my opinion. everyone that i know like the way 15/20 set up look
Old May 31, 2008 | 06:48 PM
hanguk9117's Avatar
Thanks for the response mang. Do you have any close up pics of the wheels / fenders on your set up?
jsimonk
Dec 22, 2023 03:49 PM
vitamin.v
Nov 7, 2019 06:10 PM
obender66
18 Inch
Mar 13, 2016 12:20 PM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
wuppiedog
Aug 7, 2015 11:16 AM
