Proper offset?
Old May 29, 2008 | 05:11 PM
MrHoLLyWoOd's Avatar
Proper offset?
Does anybody know the proper offset for these type of wheels, im looking to purchase 20" Axis Vips, right now i have stock 19". thx in advance for responses.
Old May 29, 2008 | 06:19 PM
nghiars's Avatar
correct offsets will be affected by spoke design
Old May 29, 2008 | 06:50 PM
redlude97's Avatar
define proper, the "proper" offset is a function of desired width, flushness, lip size, brake clearance, alignment settings and tire size
Old May 31, 2008 | 10:23 AM
Would this work on my coupe: 20x8.5 front and 20x9.5 rear. i believe the coupe is staggered, so this would be correct right?
Old Jun 1, 2008 | 12:06 PM
jhurst's Avatar
Those wheel sizes will work, but to determine which offset to purchase you need also need to factor in tire size, stock offsets are +30 and +33, and obviously you would want them to sit more flush than stock, so just check around to see what offsets others have gone with the similar wheel/tire sizes.
Old Jun 1, 2008 | 10:40 PM
How do I do that?
Old Jun 1, 2008 | 11:06 PM
releasedtruth's Avatar
Go to 1010tires.com and use the offset calculator. It'll show you how offset choices with various widths affect clearance and flushness
seagrasser
May 3, 2022 09:43 AM
Picture Share
Feb 4, 2018 12:41 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
TurTLe*
Sep 29, 2015 01:43 PM
