Tires, Spacers, Handling...Help!
Old Jul 1, 2008 | 06:39 PM
redlude97's Avatar
camber correction will also make them alot more flush
Old Jul 3, 2008 | 07:57 PM
ChichiInSoCal's Avatar
Hello all, did the search on spacers recomended for the stock G35. I have the 245/225/18 tires and reading along this thread, I think its safe to go with the 20mm spacers. Does anyone know a reputable site to buy the spacers?
Old Jul 6, 2008 | 09:34 AM
jlin615's Avatar
I've just installed 25mm in the rear, lowered on Z h-tech. Rubs a tiny bit in the rear. I think 20mm would be perfect.
Try getting some Project Kics from HR Autoparts.
https://g35driver.com/forums/wheels-tires-vendor/227856-wheel-spacers-kics-now-selling-ichiba-v2-spacers.html
Old Jul 6, 2008 | 09:50 AM
Nismo G's Avatar
spacers will somewhat hurt handling because it increases the scrub radius, but no more than low offset wheels. The "proper" way to widen the stance would be to move the whole suspension out so the pivot points would remain the same with just a wider space in the middle. Of course this isn't really feasible, and the difference is minimal and more of a factor during low speed turns, so its not something you should really worry about
How does this decrease the handling of the car? To me it seems like it would make it better. You are pushing the wheels further out there for giving the car a wider stance...wider stance = more control over the weight transfer or making the car less top heavy.
Why would pushing the wheels out make the car less controlable?
-Sean
Old Jul 6, 2008 | 03:14 PM
Xet's Avatar
Xet
can anyone share their pics after installing the spacers, i would like to see if going for the flush looking on the factory 19's is something i would like to do
Old Jul 7, 2008 | 10:48 AM
jlin615's Avatar
Old Jul 7, 2008 | 10:55 AM
dofu's Avatar
20 Year Member
-Sean
What he says makes sense... just try to draw out the difference in your mind. There is a difference between a wider stance and using spacers to make a wider stance when it comes to steering...
Old Jul 12, 2008 | 03:51 AM
c.breeze_gt's Avatar
Lisa Fleming=HOT!!!
i had the same problems with my spacers, regarding handling. i only have the 5mm ichiba spacers on all 4 rims/tires, and my handling became really bad, even with my suspension set to 3 below the stiffest. im thinking about taking them off, because i prefer handling over looks anyway.
jsimonk
Dec 22, 2023 03:49 PM
vitamin.v
Nov 7, 2019 06:10 PM
obender66
18 Inch
Mar 13, 2016 12:20 PM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
wuppiedog
Aug 7, 2015 11:16 AM
