Aggressive spacers for stock 19s
Old Jun 12, 2008 | 02:22 PM
Spdu4ia's Avatar
I see most people recomend 25mm front/rear for the stock 19's. If the car is lowered on Tanable springs i'm sure the rear would need to be rolled a little if any on 25mm spacers. Is it possible to run a 30mm spacer on the rear to get a REAL aggresive stance out back?
Old Jun 12, 2008 | 02:24 PM
redlude97's Avatar
yes if you roll your fenders
Old Jun 12, 2008 | 03:52 PM
Spdu4ia's Avatar
does anyone have any pictures of a 30mm or equaly aggressive spacer on the stock 19s?
So if you wanted a really wide stance is 25mm front and 30mm rear the optimal choice?
Old Jun 13, 2008 | 12:27 AM
Beebo's Avatar
30mm is too much... go either 15/20 or 20/25
Old Jun 13, 2008 | 01:37 AM
Triple8Sol's Avatar
15/20 is weak....don't even consider that option.
Old Jun 13, 2008 | 01:40 AM
Beebo's Avatar
^^^ fine mister 15/20 is weak... 20/25 then hahaha
Old Jun 13, 2008 | 01:54 AM
redlude97's Avatar
still weak, i would go 25/30
Old Jun 13, 2008 | 02:16 AM
Gee3point5Mhmm's Avatar
im not fond of spacers. anyone runs their car (Hard.. Sometimes) with any problem?
Old Jun 13, 2008 | 02:28 AM
Beebo's Avatar
really?
Old Jun 13, 2008 | 02:29 AM
redlude97's Avatar
really?
yes really
Old Jun 13, 2008 | 02:31 AM
Beebo's Avatar
yes really
it will look wierd tho with an 8.5 rim... when looking at it from the rear
Old Jun 13, 2008 | 02:50 PM
Spdu4ia's Avatar
why would it look wierd?
Old Jun 15, 2008 | 12:13 PM
shimmy's Avatar
I had 15/20mm on my car when I had stock 19's... I thought the rear looked a little too far out even with the 20mm in the back (this is when you look at the car from the rear). It wasn't too aggressive, but was subtle and noticable. 30mm is probably too much.
Old Jun 15, 2008 | 12:47 PM
dev1983's Avatar
anybody do this with 18" wheels? any pics?, thanks
Old Jun 16, 2008 | 04:20 PM
undefeated350gt's Avatar
spacers rock. I have 30mm in the back and 20mm in the front...
i
