Coilovers
Old Apr 23, 2004 | 05:55 PM
MEXTEP's Avatar
Coilovers
Anybody riding on HKS coils. if so, what are your opinion of them? I may be able to get a good deal on these just hesistant on doing this mod if the ride is going to be sacrificed.
I could of posted this in the suspension forum but wanted man opinion from the Sedan peeps.
Thanks in advance
Mextep
Old Apr 23, 2004 | 08:45 PM
R2 V35's Avatar
Re: Coilovers
Tein Flex, gotta have the EDFC though.... plus, throw in some sways...you will love the handling...
6MT Ivory/Willow>>Nismo OEM Kit>>Premium Package>>XM
"Tell all my people i'm a Ridah, Nobody cries when we die, we outlaws, let me ride"
Old Apr 23, 2004 | 11:31 PM
Gsedan35's Avatar
Re: Coilovers
Since you've mentioned that your hesitant because of ride quality concern's the Tein flex should not be choosen, they use springs that are 114% stiffer than stock. You want a system that is as close to possible to the oem spring rates. A good bet would be the HKS system you've mentioned. They do use very soft rear springs, so if you do push the cornering limits the car will understeer more. Another choice, that I feel is a better choice along the lines of ride comfort would be the Tein CS coilovers, which would offer the closest spring rates to oem at 392 and also give you adjustable dampners (not just adjustable ride height). But, if you have a good deal on the HKS lined up (less than $1395 I hope), go for it. Tein CS coilovers run around $1535 in case you wanted to know the price.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Apr 27, 2004 | 09:58 PM
SrunDMC's Avatar
Re: Coilovers
Keep in mind that stiffer springs don't necessarily equate to a harsher ride if the dampening is setup right. I've ridden in an S4 that ran 700/800 lbs springs mated with Koni dampeners that rode great.
Old Apr 27, 2004 | 10:05 PM
protocav's Avatar
Re: Coilovers
i have the HKS LS+ coilovers and they ride very good. i have them on full soft however. out of the box they are stiff.
Old Apr 27, 2004 | 10:15 PM
Gsedan35's Avatar
Re: Coilovers
What are the spring rates on the LS+? Are the the same 8Kg/6Kg as the LS version for the G35? I know the hypermax II uses 9/9. But zero spec's are avaliable for the LS+.
Edmund Burke
G35 6mt
Old Apr 27, 2004 | 10:29 PM
protocav's Avatar
Re: Coilovers
you can find info on the LS+ on the HKS japan website. they are 9 front and 8 rear (504lb/in, 448lb/in). the front is sprung too high, however, and i am going to change the fronts to 8kg/mm like the rear.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
