Loose Stud?!
Old Jul 6, 2008 | 10:04 PM
jhurst's Avatar
Loose Stud?!
Ok, so I go to get my new wheels installed (19" LMGT4's), only to find out that I have a loose stud on my front right side! Anyone else run into a loose stud, and how important is it (I mean, I still got 4 that work ). What is the procedure of fixing a loose stud?
Old Jul 6, 2008 | 10:11 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Loose?
The problem might be with the hub.
You need to pull the rotor off to have a look.
Old Jul 6, 2008 | 10:19 PM
MikeYo's Avatar
omg, i just had 2 loose studs after putting spacers on... holy shiet, it took 2 days and a saw zaw to get my rim off. ill post up pics in a minute. its a HUGE ordeal if you stud if completely spining. luckly for my my brother just bought a auto shop. im awaiting new lugs from H&R that should arrive tomorrow.
Old Jul 6, 2008 | 10:30 PM
MikeYo's Avatar
oh yeah, we tried to chizzle the lug apart first as you can see in one of the pics buttttt it would not let go even after it was split into 3 peices. so out cam the saw zaw and the rim came off.
Old Jul 7, 2008 | 12:29 AM
jhurst's Avatar
What made you put 2 lugs on the loose stud?? I came back from the tire shop and they had already put one on. What should I do, I tried to take the lug off and I guess the the whole stud is spinning, I can't remove the lug. Any tips? I'm pissed! Is 1 loose stud enough to worry about??
Old Jul 7, 2008 | 12:34 AM
dieselaznrock's Avatar
i dont' understand what you mean, you couldn't get the lug off the loose stud?
Old Jul 7, 2008 | 01:08 AM
MikeYo's Avatar
^^exactly, when the stud became loose the lug was just spinning with the stud. My studs only started spinning after we torqued the lugs... it was like it would start to tighten and then the lug just kept spinning. Once we tried taking the wheel back off, that when we realized what had happened. Hopefully i get my red G back tomorrow.
Old Jul 7, 2008 | 07:19 AM
jhurst's Avatar
What sort of damage did you do to your rim when you brought out the saw? The tape didn't protect it 100% did it?
Old Jul 7, 2008 | 08:16 AM
jhurst's Avatar
And just so I have some idea, what is required if I want to replace a stud? Is it a DIY type project or will I have to have a real mechanic do it?
Old Jul 7, 2008 | 03:33 PM
slow600's Avatar
U can usually drill the lug and stud from the center and it will break apart. Yes its a do it yourself job if u have the right tools. I work at a tire shop take less then five minutes with hub off
Old Jul 7, 2008 | 09:15 PM
jhurst's Avatar
UPDATE: so I messed around with it some more, got the lug nut off just by spinning it as quick as possible......so hooray , but wait, I notice that the stud has fallen back all the way back. So I try to give the G a testspin but I don't make it 4 inches as it seems the stud is hitting on something (on the hub?) not allowing the hub to rotate. I try to hammer the stud out of the back, but no luck, it seems as if its hitting something. So, for now, my car is stuck in the garage, not able to make it to the dealership.
If I get the wheel off, will I be able to get that stud from behind, and what is keeping the stud from going out of the back?
prinny
Nov 22, 2015 11:07 PM
the93owner
Oct 4, 2015 09:40 AM
w4kj4k
Oct 2, 2015 07:57 PM
AT23
Sep 15, 2015 07:44 PM
