Loosing 2psi per month normal on 20s???????
Old Jul 18, 2008 | 07:19 PM
mpapers's Avatar
Hey guys,
I recently put on 20" sevas with yokohama s drives and im consistently loosing about 2psi in all four tires per month. Is this normal? I have check to make sure i have no nails or anything. I run 37psi in the rear and 39psi in the front.
Old Jul 18, 2008 | 07:25 PM
phatbuddha's Avatar
No.
Old Jul 18, 2008 | 09:12 PM
bigc's Avatar
Wings Nation
how long have you observed this decrease in pressure?
Old Jul 18, 2008 | 09:33 PM
mpapers's Avatar
over a month i lost 2psi per tire. I have only had the tires for 3 months and ive refilled them once already.
Old Jul 18, 2008 | 09:35 PM
MikeYo's Avatar
Ive never had this problem and ive had my 20's for about a year now.
Old Jul 18, 2008 | 09:43 PM
mpapers's Avatar
what kind of wheels and how much psi do you run??
Old Jul 18, 2008 | 09:49 PM
rookie's Avatar
Some chrome will get damaged by the lube used during mounting, other than that temp changes can effect the psi.
That seems like high psi in the tires.
Old Jul 18, 2008 | 09:56 PM
mpapers's Avatar
^^^Who asked about chrome????
Old Jul 18, 2008 | 09:58 PM
rookie's Avatar
I'm saying chrome barrels can leak air. Adding info to the thread, wasn't assuming you had chrome barrels.
Old Jul 18, 2008 | 10:01 PM
mpapers's Avatar
ohhh Well the lip is chrome but not the full barrel... I was reading that in warm climates with temperature fluctuations causes alot of psi loss. Also in case anyone is wondering i only check psi at night after its been sitting for at least 6 hours to insure accuracy.
Old Jul 18, 2008 | 10:02 PM
mpapers's Avatar
btw rookie that whip is ridiculous!!!!!!!!!!!!!!!
Old Jul 18, 2008 | 10:04 PM
rookie's Avatar
haha, thanks man. I'd keep monitoring it if you're concerned. Like bigc asked if it were a thing you noticed over 6 months there might be something wrong.
That tire pressure is a little high no?
Old Jul 18, 2008 | 10:09 PM
mpapers's Avatar
Well when i bought the tires i called Yokohama and they advised me those psi specs based on the load indexes on the their tires. I just read read that in warm climate with temp fluctuations it is actually normal to loose about that 1 psi a month. Im assuming since i also keep a high psi that might push more air out faster.
Old Jul 24, 2008 | 11:06 PM
Evil350GT's Avatar
Fill them with nitrogen.
Old Jul 24, 2008 | 11:21 PM
acr's Avatar
acr
39 psi is high for 20s? on my old car with 20s, I ran 50 psi front and rear with 255/35/20 tires. It was a Grand Marquis so it still rode super smooth. With low profile tires, the risk of denting the rim is too high to not run high pressure.
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
zcherub
Aug 30, 2015 05:04 PM
Phenomenon9
Aug 9, 2015 01:34 AM
