Endless/Zeal coilovers?
Old Apr 30, 2004 | 12:39 AM
SrunDMC's Avatar
Anyone have any idea when these will be released for the G35 coupe? I've heard good things about them, but really don't know a whole lot about em.
My choice for my 6MT coupe is between the HKS Hypermax LS+ and possibly this Zeal suspension. What do you guys think?
Old Apr 30, 2004 | 01:18 AM
Gsedan35's Avatar
Re: Endless/Zeal coilovers?
Info I've seen on my350Z.com that say's the Zeal's will sell in the $2200-$2800 range. I'd have to know why it should be picked over the Tein flex to justify the $$. I still want someone to post the spring rates for the HKS LS+, since the regular LS has poor spring rates for G35 applications. Tein will be releasing their SS coilover with will undercut the LS+ in price, should retail for $1200 and street for less then that, spring rates will be 9Kg/9Kg.
What coilover to get depends on what brand you trust. What you want out of your car after they are installed, which relates to how they are valved (comfort, aggressive street, or track) and what spring rates are used.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Apr 30, 2004 | 06:04 PM
FluxG35's Avatar
go with HKS LS+ or Cusco Zero-2.. Zeal is too pricey, if you got money get them... I'm getting HKS LS+ from Gruppe-S
<font color=blue>*2004 DG 6-MT/Team Kinetix. Sponsor by: Audioplanet,EF1Motorsports, DPE Wheels, Stillen</font color=blue>
Old Apr 30, 2004 | 06:18 PM
SrunDMC's Avatar
spring rates for the LS+ setup are 496/440 and for the cusco zero2 is 560/392.
it's interesting how the cusco setup actually decreases the spring rate in the rear, huh?
Old Apr 30, 2004 | 07:33 PM
RacingDynamcs's Avatar
ZEAL is a great suspension maker. They recently proved their technology on the JGTC. You can basicaly buy the exact stuff they use on the tracks.
They are known for quality work and reliability also their overhaul prices are good from 120-140 each.
HKS is good suspension but as far as quality and performance of the coilover systems Apexi N1's are the best in japan. But the cost is unless you use the N1 for tracks only they wont last very long, just like anyother coilover set with real stiff spring rates and stiff inbound and outbound ratings.
Old Apr 30, 2004 | 09:10 PM
Gsedan35's Avatar
SrunDMC ()
04/30/04 03:18 PM
__________________________________________________ _
Thanks for the spring rates on the LS+, as I feared like the LS coilover for the G35 and the Cusco's they do not use spring rates that are sensicle, at least the LS+ is not as bad as the LS or the Cusco's. Oem rates are 314/342 with motion rates of .79 front and a very low rear motion rate of .36, that is why the oem spring rate is higher in the rear. Sway bars are not designed for tuning out such a large transfer of roll stiffness, sway bars are to be used to fine tune a setup that is already properly dialed in.
HKS LS+ 496/440 +58%front +29%rear $1600-$1800?
transfers 29% roll stiffness to the front
HKS LS G35 448/336 43%front -1% $1377
transfers 44% roll stiffness to the front
HKS LS 350z 448/448 43%front +31%
transfers 12% roll stiffness to the front
Cusco Zero1&2 560/392 +78%front +15%rear $1300-$1600
transfers 63% roll stiffness to the front (rear spring location remains in OEM location, rear springs are NOT on the dampner body, which would explain the weak rear rate)
HKS II 504/504 +61%front +47%rear $1600
transfers 14% roll stiffness to the front
Tein SS (same specs are HKS II above) @$1200 retail
E.T.A. T.B.A.
Tein Flex 672/672 F+114% R+98 $1510
Transfers +16% roll stiffness to front
Tein CS 392/392 F+25% R15%
Transfers +10% roll stiffness to front
Nismo S-tune* 448/504 F+43% R+48% $1200
Transfers +5% roll stiffness to rear
Not a coilover, listed for spec comparision only
Jic Flta-2 *350Z fitment 560/672 F+78% R+98% $1750
Transfers +20% roll stiffness to rear
Jic Flta-2 G35coupe 560/560 F+78% R+64% $1750
Transfers 14% roll stiffness to front
Tein Flex JDM* spec special order only $1510
specs are the same as Jic Flta-2 G35coupe listed above.
*unknown if it uses the revised CS type upper mounts
D2 Racing 840/728 F+168% R+113% $950
Transfers 55% roll stiffness to front
Edmund Burke
G35 6mt
Old Apr 30, 2004 | 09:48 PM
THX723's Avatar
G Kreuzer
Buddy Club is also set to release their Z and G coilovers in the near future. I've tried, but their US distributor (AJ Racing) will not release any details untill released. What is known is they do employ the largest piston size (46mm and true for all Buddy Club systems) in the market. It will also likely be 15-way adjustable.
http://www.aj-racing.com/BC-suspension.html
(under Racing Spec Damper)
Great work by Gsedan35 regarding the availability of the JDM spec Tein Flex. EDFC die-hards need not settle for the hideous 12kg/mm US-spec FLEX ride or the lack luster 6kg/mm CS cushion any longer.
Clint (THX723)
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
