Help Tire Problem
Old Jul 23, 2008 | 03:51 PM
adog35's Avatar
Help Tire Problem
So i just got new rear tires for my 04 Coupe and i am having a lot of problems with the traction control and the ABS turning on a lot. In the rear i have 255/45r18 Brridgestone Potenza RE050A and in the front i have 225/45r18 Bridgestone Potenza. I believe my problem is because the tires are different kinds of Potenza. The rear are sport tires with 140 Thread-wear and the fronts are 440 Thread-wear and are touring tires. Is this the problem? I can even go around a corner with out the traction control going on. It never use to do this before when my old tires in the back. They were the same kind as the fronts but they were 245/45/r18
Old Jul 23, 2008 | 03:54 PM
Hi-TechG35's Avatar
Do you have TPMS? If so they may need to be reset.
Old Jul 23, 2008 | 05:57 PM
adog35's Avatar
yes i do but i do not see how that would cause ABS and traction control to turn on
Old Jul 23, 2008 | 08:00 PM
nghiars's Avatar
sounds like VCD is going off due to the different gripping levels of the tires... the compound of the rears will stick alot more than the front thus VDC thinks your front tires are slipping.
Old Jul 23, 2008 | 08:24 PM
redlude97's Avatar
sounds like you need new front tires with better grip, its the VDC tripping out most likely
derres
Aug 28, 2015 03:27 PM
Fireman07603
Aug 9, 2015 06:00 PM
Srinidhi
Aug 7, 2015 03:38 PM
wojowojo16
Jul 27, 2015 09:57 AM
Soumilg
Jul 18, 2015 12:33 PM
