Rim rust. HELP!.
Old Jul 24, 2008 | 01:49 AM
HellaFly's Avatar
Rim rust. HELP!.
Well i picked up a set of oem coupe 18'' rims for cheap, and they have this rust like residue on them. I was wondering if anyone knew of any cleaners that would remove this or any idea how to.
Pics:
Thanks
-Vick
Old Jul 24, 2008 | 01:58 AM
BlueDevilBAMF's Avatar
I'm pretty sure that's burnt-in brake dust...
Anyhow, even if you get it off the finish might be toast. Might want to consider repainting them if that's the case But they're certainly worth trying to clean at first.
I've never cleaned wheels with anything that bad. But I can tell you a wheel brush is something you'll definitely need.
Old Aug 18, 2008 | 07:06 PM
truzaro23's Avatar
only way your getting that off is if you use one of those double sided dishwashing sponges with one side sponge matieral and the other side brilloish matierial ...that should take it off..just be gentle!
Old Aug 18, 2008 | 08:14 PM
EvolutionGSR's Avatar
do you have access to a pressure washer? I have an 1800 psi one. Not sure how bad it is but might be worth a try.
Woops just realized you're not even in the same country...sorry I was gonna offer.
Old Aug 19, 2008 | 12:35 AM
SVLRx's Avatar
yea, looks like brake dust that's been on WAYY too long... You're going to be scrubbing for a while...
Old Dec 30, 2008 | 07:44 PM
Halcyon777's Avatar
LA's Awesome Clean will take that right off
Dont let the product dry and absolutely keep it away from the car paint, its likely to eat away at the clear coat.
Old Dec 31, 2008 | 01:09 AM
Gorg3ou5's Avatar
Jen Eric
dseet
Oct 11, 2015 12:40 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
inexorable
17 Inch
Sep 24, 2015 10:43 AM
