20" PSI for potholes/street driving
Old Aug 7, 2008 | 06:00 PM
elayman's Avatar
There are quite a few potholes and such around where I live and was wondering what a good PSI is to keep my 20" tires. Should the rears be 2 psi higher than the fronts? I just saw a couple of threads about this and didn't really understand why.. also, I've never personally put air in my own tires so should I ask someone for help when I go to a filling station? I read on the tires that it says max psi 50, but it says never exceed 40 psi.. I think the fronts are at 36 right now and im not sure about the rears
Old Aug 7, 2008 | 06:06 PM
miltoda's Avatar
I run 32psi in my 17s all around. 36 probably will do for all four tires. Filling a tire will air is probably the simplest thing you can do in owning a car. Just get a 12v car air compressor from sears or wherever and a digital tire pressure gauge. That should only set you back 40 bucks total.
Old Aug 7, 2008 | 06:07 PM
elayman's Avatar
can't i just go to a filling station or w/e and use theirs? do they charge you to use their air :P. my friend's got an air compressor for like painting and stuff but would that work for filling up my tires?
Old Aug 7, 2008 | 06:53 PM
acr's Avatar
acr
I would run the max recommended pressure. On my last car, I ran 50 psi all around.
Old Aug 7, 2008 | 07:06 PM
redlude97's Avatar
Run what is listed on your door
Old Aug 7, 2008 | 10:49 PM
DHCrocks's Avatar
I use 40, much higher and the ride gets really rough. Even at that, I managed to bend my rear on a pothole, and thats on a forged DPE. my advice is to avoid the pot holes at all possible costs. No matter what pressure you use a 35 series does not offer much if any rim protection.
Old Aug 11, 2008 | 11:26 PM
mpapers's Avatar
Call your tire company and they will calculate the load index's compared to the oem tires and give you new psi. I bought Yokohama s drives for my 20s and they gave me 39 front and 37 rear. IT DOES NOT GO BY YOUR DOOR. DIFFERENT TIRES HAVE DIFFERENT LOAD INDEX'S!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
Calvin
Southern California
12
Oct 15, 2015 04:21 PM
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
joedaddy1
Jul 28, 2015 02:58 PM
