Have a 03 black sedan with Yokohama Avid 4's. This tire grips very well but I am getting alot of road noise. To be honest I don't drive THAT spirited but would like a tire with decent grip and comfort. I had a set of Kumho's Ecsta on my last car (I30t) and after 15-20k they started to get noisy but maybe it was my fault? The Yokohama and Kumhos seem to be the best bang for the buck tire. What are your thoughts? Thanks in advance.
Sam
Sam
I have the avid v4s tire as well. How many miles did you get out of them? I found they were as quiet or quieter than the crapanzas el42s that come on the car.
A friend of mine suggested Hancook when i was getting new tires. I think they are budget friendly as well.
I estimate the Avids have 30-35k miles but are getting noisy. Its driving me crazy. Still have quite a bit of tread left. Originally Posted by miltoda
I have the avid v4s tire as well. How many miles did you get out of them? I found they were as quiet or quieter than the crapanzas el42s that come on the car.A friend of mine suggested Hancook when i was getting new tires. I think they are budget friendly as well.
Any of the Crapenzas suck IMO. I had them on my 02 Maxima and hated them. Noisy, hard as a rock, terrible wet traction, etc....I have never had good luck with Bridgestones.
Texasscout
close
- Join DateFeb 2005
- LocationSouth Texas
iTrader Positive Feedback100
iTrader Feedback Score(11)
Liked:2,116 Times in 1,768 Posts
I had Goodyear RS-A's on mine for a while. I went up in size to 245 45 18's, it helped with noise and ride confort. The taller the side wall, the better the ride.
you may want to get your tires rebalanced...that may help with the road noise, but V rated tires and in general tires get louder the older and more worn they are.
The avids have a 60k mile treadlife warranty...if you do have to replace much sooner than that, at least you can get a prorated discount on the next set.
Your right, may need to get re-balanced as I notice it is pulling left. The alignment is ok.
gary c
close
- Join DateFeb 2005
- LocationValencia, Ca
iTrader Feedback Score(10)
Liked:1,133 Times in 1,003 Posts
Quote:
The noise you're hearing has nothing to do with balance. If your tires are out of balance you'll feel a vibration in the steering wheel. Is you car pulling to Originally Posted by sleeper22
Your right may need to get rebalanced as I notice it is pulling left. The alignment is ok.
the left during braking or does it just wander left while driving? Those are two
different issues with two different causes. I'm currently running damn Bridgestones (came with my wheels) they are super noisey. Going back to my
Michelins by next summer....for sure!
Gary
Gary
Does not pull at all under braking only while driving and especially at higher speeds. Pulls very noticeably left. Only started doing this after tire rotation.Originally Posted by gary c
The noise you're hearing has nothing to do with balance. If your tires are out of balance you'll feel a vibration in the steering wheel. Is you car pulling to the left during braking or does it just wander left while driving? Those are two
Gary
Quote:
You may change your mind if you try the "Turanza Serenity." I find it more than adequate in dry weather, and have never had a tire that was better in the rain. Last winter I had to find snowy side streets to test them -- and immediately learned that I don't need snow tires. They did just fine.Originally Posted by sleeper22
Yes, quiet and comfortable.
I will check them out. Maybe these are much better?Originally Posted by Dan in St Louis
You may change your mind if you try the "Turanza Serenity." I find it more than adequate in dry weather, and have never had a tire that was better in the rain. Last winter I had to find snowy side streets to test them -- and immediately learned that I don't need snow tires. They did just fine.Yes, quiet and comfortable.
The Potenzas I had were awful and any other Bstone tire in the past were like rocks.
Quote:
I would look at your front tires and see if they are worn different, especially the inner part of the tread tread.Originally Posted by sleeper22
Tire Rack reviews are very positive.Originally Posted by Dan in St Louis
Dan how many miles do you have on the Serenity? How do they handle? Thanks!Originally Posted by Dan in St Louis
Sam
I just bought Sumitomo HTR+ tires for my coupe, Im pretty happy with them, millions more quieter than the BFG's I had on there.
I find there breakaway more predictable and dry grip is fine for what Im used to. They also have low M+S rating where as similar tires did not. Tirerack has good prices on them as well.
Maybe also look into the Kumho AS-T, I had it on another car and liked them, told my bro to get them and he is happy as well.
