SPC front camber kit install questions
so i put on my SPC front and rear yesterday and now all the lights are on. i did not use the spacers but i did use the new abs bracket...i'm thinking that's the problem? if i put the spacers on i'm pretty sure my lights will go off...at least that's what i've read but does that mean i have to take the whole hub off and install the spacers on that side? that's the only way it makes sense from what i'm seeing...the instructions for this kit is horrible. are the spacer's required? i know it gives you additional camber and my car is slammed on flex coilovers but i'm hoping i'll be able to get it in within spec without the spacers? oh and is it skinny side down or up? i'm thinking skinny side down?
also for the rear do you HAVE to elongate the hole for the toe bolts? i think my buddy said they just went into the stock hole?
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
